View unanswered posts | View active topics It is currently Thu Jun 27, 2019 1:46 am
Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 strange sound when cold -Now hot
Post strange sound when cold -Now hot
hey there
i got a really annoying sound lately when my bike is cold and i open the throttle
the sound appears when i let off the throttle it also appears when i take a right corner
but strangely in the center stand no sounds at all :doh:
its sounds like a clutch issue or something but it can be the bearings
here is what i captured today
Any help is going to be appreciated :)
Image rolling on http://www.alternagreece.com
Wed Feb 11, 2015 5:06 am
Post Re: strange sound when cold
since you mention cold
is it that little whistle noise
because I really cant hear anything else
but because you said cold, check the valves
maybe cam tensioner is going bad, they go bad on other bikes enough where people sell manual tensioners
but for the zuma you can just buy a new one its pretty easy to replace
sometimes the license plate rattles easy to check that just shove a towel behind it
also did you remove any covers recently thats another way to hear weird noises
like engine cover, or cvt cover they are there to muffle noises so if removed you hear more stuff
oil level correct, and correct type of oil for cold weather?
Wed Feb 11, 2015 6:52 am
I heard nothing of concern (it may be annoying to you).
You might try your test again with the CVT cover removed.
I hear a slight whirring when you hit the throttle, that could be the belt on variator, the belt on clutch or it could even be the clutch shoes on clutch bell.
Really don't hear anything that I'd call AN ENGINE SOUND.
Wed Feb 11, 2015 10:10 am
well at 0:34 you can hear it ringing (maybe its in my mind)
my bw's is totally stock only dr pulleys in the vario
the oil i use its a castrol 15w50 synthetic i use it since 1k km( im at 7.3k)
i changed final drive oil yesterday with a 10w40 i had.
last time i opened cvt cover was about 1 month before to check the belt etc.
so the things i have to check: cvt cover,engine cover fan cover may etc, valves, cam tensioner(really duno how)
and post back
Wed Feb 11, 2015 1:37 pm
15w50 is way to thick of oil
should use 10w30 for both engine and tranny oil
everything I listed to check is shown in the service manual how to do it and what tools are needed
here is a pdf
https://docs.google.com/viewer?url=http ... f?time%3D0
Wed Feb 11, 2015 1:58 pm
i il change oil again at 8k +
isnt the 10w30 oil too thin for wot rides and soon warm weather ?
thnx il check the manual for the rest tasks
Wed Feb 11, 2015 2:25 pm
they used the 50 on 200+cc zumas
so if yours isnt 200cc then its too thick
Wed Feb 11, 2015 3:26 pm
This problem was fixed after changing the final trans oil
But it gave place to another sound that i'm hearing lately when the engine is hot and under load (acceleration steep hill second passenger etc)
here is what i captured with my phone https://soundcloud.com/dimitris-prassas ... 3-12-37-05 1.11 1.37 1.52
sounds like a knock or something . . .
what i checked so far : oil level
new spark plug
optical inspection on the cam tensioner
anything else that could be related ?
Wed Jun 03, 2015 4:33 am
Post Re: strange sound when cold -Now hot
I got new computer speakers
and listened to the original video
I think the sound im hearing is the clutch bell pinging when you rev it the clutch pads hit it
listened to the new sound file, but dont hear anything wrong
did you check the valves and change the oil yet to something thinner
you could always go with a louder exhaust that way it hides some noises
Wed Jun 03, 2015 7:02 am
Valves have not been checked yet and as far i know they sound mostly when its cold.
Oil now is 10-40w synth
at first i thought about detonation but after some fresh gas and new spark plug the sound is still there .
Could be a rod bearing with just 9k kms on the clock on a stock engine ?
Wed Jun 03, 2015 10:46 am
anything is possible
who knows if that thicker oil put too much stress on the parts when it was cold. how often it was changed things like that
plus dont know what mods you have done on it
Wed Jun 03, 2015 11:38 am
confirmed: ticks with valve here. mine was to tight and it would tick like crazy. but it was constant. not saying that sound couldnt be that issue though. high rev... could produce a tick. but I am wondering if its a baring of some sort. its tuff to tell from listening to a bike on a computer.
Wed Jun 03, 2015 11:43 am
Just to clarify.. its the faint whistle toward the end of the Peak of the rev is what you are concerned with? because everything else i hear sounds normal...
I mean... check your throttle spring and see if it needs lubed cuz it could be the swing back of the throttle making that sqeek, the cable in the cover?... i know that may sound super bozo... but try to listen to the source and think simple before we start telling you to crack the case and replace a crank seal. lmao
Wed Jun 03, 2015 11:47 am
ive had a few bikes that ive put manual cam chain tensioners on because of the ticking
its caused from tensioners that tighten too much and over time can cause major problems
manual you can set how tight it presses against the chain get rid of any ticking noises
my most recent bike bought brand new had the ticking around 4500 miles
just put on the manual tensioner at 6000 miles and its back to silent again
you would only hear it around 3000rpm in 3rd gear but I knew what was causing it
of course ive never seen any made for the zuma yet, but a new tensioner and gasket is cheap and easy to replace just 2 bolts
If you have lets say 10,000 miles then I would change it out
just to be safe
Wed Jun 03, 2015 11:55 am
@Lamb K 55 im pretty sure you talking about the 1st post vid that it no longer exists ,it could be the clutch hiting the bell or something.
@ZUMIKE my scoot is stock engine wise just dr pulleys on the vario and thats all
the oil that you referred 15-50w was from the certified dealer here il take it for a check cuz im still under waranty .
Il have to check the valves and cam tensioner for now
Wed Jun 03, 2015 12:17 pm
