View unanswered posts | View active topics It is currently Wed Jun 26, 2019 11:38 am
Reply to topic  [ 10 posts ]
 2015 YAMAHA BW'S R
Post 2015 YAMAHA BW'S R
Yamaha just previewed the new BW'S R . I really like the new headlight design but the taillights seem a bit bulky. Not sure about the engine specs but I'm assuming its the same 125. Also looks like rear disc !
2011 BWS-125 - Michelin Power Pure SC (oem sizes) / GJMS Low Down Forks / GJMS GP2 40mm lowered rear shocks / GJMS 260mm Rotor with NCY Caliper Adaptor / TST Variator / HARDY low handlebars / KOSO Clutch Bell / KOSO clutch / Daytona Kevlar Belt / NCY bearing kit / 1000 RPM Contra Spring / Zubiku : Carbon CVT Cover + Airbox Cover + Short Rear Spoiler / Simota Air Filter / Dolphin CNC Drain Heatsink / KOSO Afterburner Tails / Smoked Signal Covers / Race Fan / GJMS CNC Speedo Cable holder / dual 15w CREE LED headlights with ecode clear headlight housings.
Mon Jun 15, 2015 11:05 am
Post Re: 2015 YAMAHA BW'S R
need more pics and specs before I comment
there was the bwsX 125
thats available overseas
I think its just different brake upgrade and the digital speedo, maybe paint job too
Mon Jun 15, 2015 11:48 am
scooters and mods: 155 BBK w/cam, TST with 8/12gr, 1000rpm spring, Polini 42:13 gears & K-belt, GJMS GP-2 r-shocks
I see a big front disk and performance/street tires (and passenger foot pegs) - it would be interesting if was built around their new 155.
2009 BWs 155 RC BBK plus cam, Simota drop-in air filter, Leo Vince exhaust, TST variator (10/12 gr sliders), Stage6 clutch, Prodigy torque-driver and clutch bell, 1000rpm spring on NCY bearings, Polini 13:43 gears and kevlar belt, GJMS GP-2 rear shocks & 260mm front disk with NCY steel line, Trickle X highway pegs, C3 mirrors on extenders, Michelin Power Pure SC tires
Mon Jun 15, 2015 4:48 pm
thats what I was wondering with that rear brake too
but if it is a 155
its really not that hard to convert the "old" zumas to that for very little money especially when you can pick up used ones really cheap
wonder how much that bike would go for here
we need a grom killer instead of a new scooter
Mon Jun 15, 2015 5:01 pm
the blue reminds me of the old pre bug look
so fuel filler is in the wall, tank must be under the floor
I can see nice stains dribbling down the wall if you over fill it
it already stains the black plastic on the 125 models with the tank in the seat
I did see a 200mm mentioned when looking at the engine
but then 29 Liters??? when looking at the trunk
price?
78500 New Taiwan Dollar equals
2540.782 US Dollar
Tue Jun 16, 2015 8:42 am
this was unveiled a few months ago I think.. its OK looking
2009 Zuma 158cc with New 2015 Cam from RC Scooters. Sami X rear suspension, GJMS Custom low forks. vertical headlight front end. TST vari, RRGS clutch bell,
Tue Jun 16, 2015 9:14 am
The headlights remind me of the headlights on the new Piaggio Typhoons, even though the Typhoon lights are more recessed into the front fairing.
2003 Zuma
(tuning)
Stage6 HPC 10mm crank
Malossi MHR Overrange (24.3g)
Malossi 107mm MHR Wing Bell
Malossi Yellow Contra Spring
Malossi Torsion Controller
RFY Shock
Stage 6 F1 Mirrors
Stage 6 14/42s
NGK BR9HS
Michelin Boppers
Trail Tech Vapor
LEDGlow Underglow Kit
Tue Jun 16, 2015 6:31 pm
scooters and mods: Zuma 125
From left to right: BWS100, BWS125, BWS125-R
You'll notice that this is an all-new machine; not just cosmetic changes, but a physically larger machine.
It still has an air-cooled 125c engine, but I'm not sure of more than that.
Zoƫ Washburne: [about Serenity, on first seeing her] You paid money for this, sir? On purpose?
Sun Jul 05, 2015 10:05 am
Wonder if the wheels can be swapped onto a older model. Nice colors
Sun Jul 05, 2015 10:18 am
Fashions are social thinking marvels common to many arenas of human activity and thinking. The rises and falls of styles have been especially documented. Womens Leather Jackets
Mon Jul 09, 2018 5:55 am
