View unanswered posts | View active topics It is currently Fri Jan 18, 2019 9:39 pm
 Feign urb for zuma125
Post Feign urb for zuma125
I have a Zumba 125 with a enviromoto big bore kit on it and just installed a feign urb.Does anyone out there know what setting to use on the urb the dial on the box is on 0 from the factory.
Sun Apr 09, 2017 12:20 pm
Post Re: Feign urb for zuma125
did that bbk come with a camshaft and matching injector?
did that injector come in a black SRP box?
if yes, remove that control box, not needed.
the injector is matched to the camshaft and bbk. works perfectly fine on a stock throttle body.
only time need a fuel controller is when you go larger throttle body.
http://www.rcscooters.com
Sat Aug 12, 2017 4:46 pm
