View unanswered posts | View active topics It is currently Sun Feb 17, 2019 4:09 pm
 My TST thoughts
Post My TST thoughts
So I already had the Race Concepts BBK installed with the stock CVT. For the TST install, I used 9/11 rollers with the 1,000 RPM spring and stock shim per Chris's recommendation. In this configuration, it doesn't jump off the line as quick as stock (very close though), but power is much more linear all the way to top speed. Top speed also increased 4 mph from 59 to 63 indicated. I'm happy with it and I will probably stick with this configuration for now.
Thu Aug 24, 2017 8:22 pm
Post Re: My TST thoughts
So I did a top speed run with a GPS speedometer app and it said 65! So with just the variator my top speed went from 57 to 65. Guess I won't need to change the gearing, but I have no plans to run it over 60 at any time.
Tue Aug 29, 2017 6:16 am
if u don't plan to ride it top speed much.
go with 9/10g rollers, this make it rev higher out the hole and better launch and mid speed performance.
9/11 was for people who do ride 60+ often.
another one u can try is 9/11 and stock shim plus a thick tst shim. this drops the belt more on the crankshaft side so belt can sit higher on the rear torque driver and this gives it better launch but takes longer to hit top speed. or even 9/10 with that shim setup and really give it all on off the line.
have fun! tnx for the support.
http://www.rcscooters.com
Tue Sep 26, 2017 10:27 am
