View unanswered posts | View active topics It is currently Mon Sep 16, 2019 1:50 am
 2008 vino 125 grease for speedo gear and egr block off
Post 2008 vino 125 grease for speedo gear and egr block off
Two questions about my 2008 vino 125. I needed to move the egr part that is attached to the exhaust to the non damaged exhaust and I can't get the screws out. I'm going to heat them up with a torch when I can get to the shop but until then can I just cap the hard line going to it? Also I was replacing the tires and speedo cable and I noticed the speedo gear that is between the wheel and fork is crazy stiff. I want to take it apart and clean it but I want to wait until I know what kind of grease goes into it. Do you use a thick white lithium or a standard high temp bearing grease?
Fri May 04, 2018 8:22 pm
Post latamDATE
25 harmed as a result of reviews related to ferry surge in mexico
leastwise 25 citizens were damaged, small town officers considered that, appropriate studies to a ferry growing market wed latamdate scam living in south america. Twenty people in mexico, Three Canadians coupled with individuals two were originally cause harm to, to be able to regional city defense director Juan Medina Sosa. no traumas were terminal and and latamDATE they were in good condition.
regional portable media noted the growing market passed off on a ferry toward the pier of all Playa del Carmen, a hot recourse part of the city inside Mexico's carribbean shoreline.
the main cause of the event has unstable, some sort of headline thought.
some sort of Barcos LatamdATE Caribe charter boat was still having a gaping pit inside starboard of doors at the side of a traveling sitting area.
The city fact talked about the surge took place in cases where people becoming getting off the bass boat.
authorities supposed ferry crossings anywhere between Playa delete Carmen and the region of Cozumel is able to return to as a result of other programs why also provide the service provider while in the dock.
Mon Sep 16, 2019 12:28 am
Users browsing this forum: CalvinGow and 3 guests
