View unanswered posts | View active topics It is currently Tue Jun 18, 2019 6:28 am
 Error code 19
Post Error code 19
Hi all
I have a bws 125 on 2014 plate and to cut a long story short the local thugs got hold of it and ripped my front panel off smashed up the ignition barrle and hot wiered it so it's now giving me error code 19
I have looked this up and to what I can find it's no signal form ignition to ecu
Is there a way to buy pass this code or will i need a full new ignition system
Thanks for looking any help would be appreciated
Thu May 17, 2018 12:19 pm
scooters and mods: 2009 125
Post Re: Error code 19
Theres a Male - Female plug in connector (1 wire) down by the battery with a large black cable. Make sure that is plugged in securely. Also check the two wires connected to the coil and trace them for damage.
Those can cause some starting issues.
2009 Zuma 125 Blue & Black - Second Engine
2009 Zuma 125 Black & Yellow (RIP)
Thu May 17, 2018 3:40 pm
