View unanswered posts | View active topics It is currently Tue Jun 18, 2019 8:20 am
Reply to topic  [ 1 post ]
 2 Bros Juicebox Pro fooled
Post 2 Bros Juicebox Pro fooled
155 bbk, 4 hole inj, cam, 2 bros pipe, juicebox Pro.
I was doing a burnout to wear out an old tire, and this was the first burnout since installing juicebox. The ecu was always thrown off by doing burnouts, (no speed, but lots of load and throttle), but would always recover. Not so with JB. Scoot died after shut down of throttle...........would not restart. Had fire, new gas, checked all connections, reset ecu............nothing worked, but it would 'fire' while on the starter. Pipe would be hot, but would not run w/o starter helping. Anyway, finally disconnected JB and reset ECU and it runs like a champ.
So, do I really need JB to run this set-up? I'm going to monitor plug to see if I can tell if it's running lean, but it starts better and seems to run just as well.
What's everyone's experience with this situation?
Sun Jul 15, 2018 11:11 am
