View unanswered posts | View active topics It is currently Tue Feb 19, 2019 4:41 pm
Reply to topic  [ 15 posts ]
 Oil in the airbox? Drenched air filter
Post Oil in the airbox? Drenched air filter
So 2 days ago I got to my buddies to get ready to leave out on a road trip. on the way to his house the zuma felt really sluggish. I checked my zuma 125s oil and it was low. We went to walmart and bought some 4 stroke oil 10-40w. We left for the road trip and I left my zuma parked in his garage . We got back last night about 2 am... I put in 25% of the bottle and got all my riding gear on. exhausted I forgot to put the dip stick back in and started my bike. My buddy saw oil spit out and quickly stopped me. I put the dipstick in and headed home. I could not get above 45mph on the way home. It would accelerate then loose power then give me a jolt of acceleration again. I pulled my bike out this morning and there was oil leaking from the aitbox. I unscrewed all the screws and oil came pouring out. about 3 inches of oil was standing in the air box. What would cause this?
Mon Jun 30, 2014 12:42 pm
Post Re: Oil in the airbox? Drenched air filter
did you over fill the oil?
you have a breather hose going into your air box, may be a gray color
you also have a drain hose coming out of the air box, red color with a cap
if you overfilled, oil blew out the vent into the air box and did what happened
or, you never drained the red line and over time its got full, and if the oil vapors have no where to go they soak into the filter
I would suggest drain all the oil into a measuring cup
I think the bike holds 950ml of oil
see what you took out
and replace with the correct amount
Bike must be level when checking and dont screw in dipstick
just drop in the hole and read it
you want to be in the XXXXX marks
I shoot for the center of the XXXXX
as for the filter
now is a good time to upgrade if you havent
I think drow sprots sells the blue simota filter
its like a k&n type
you can oil it, clean and reuse it too
Mon Jun 30, 2014 12:48 pm
http://www.drowsports.com/simota-yamaha-zuma-125-high-flow-air-filter/
Mon Jun 30, 2014 12:49 pm
I believe that you've overfilled your crankcase too
that will cause all the other problems that you described
having too much oil may do more damage than not enough in some instances
try to clean up the mess ... you should be fine
cleaning the oil out of the airbox is going to be the challenge
be really.really careful cleaning the TB ... that's where to FI/ECU sensors live. They're dilicate
Mon Jun 30, 2014 7:16 pm
Were you able to find a solution to your problem?
The exact same thing happened to me, and my oil levels were normal, even less than full. Now, the engine will turn, but won't start.
Sat Jul 18, 2015 7:16 pm
if you have been burning oil, you may have fouled the spark plug
change that out and try to start it
if yours is a 2009, there is a fuel pump recall because they went bad
if that doesnt help, the biggest sign of hard to start engine, that has been known to run could be out of spec valves which need to be checked every 2000 miles
Sat Jul 18, 2015 7:30 pm
Hi Mike. It's a 2009 Zuma, with a new fuel pump, new spark plug, brand new bbk, new camshaft, new starter, timing is aligned, valve Springs in spec, all nuts and bolts torqued to spec, new seals/gaskets, new fuel injector, new belt, new timing chain sprocket, new cylinder head camshaft.
After building the new engine, the Zuma ran fine running under 40mph. Then, when we tried to go full throttle, it lost power and everything at 40-45mph.
I drained and refilled my crankcase and transmission oils.
Fuel is pumping fine, spark plug is sparking. No check engine light. It's quite a puzzle.
Sun Jul 19, 2015 10:50 am
probably had too much oil in it then
thats why it was blowing out
its stamped either on the engine, or that plastic cover how much oil it holds
I suggest draining out the oil, measuring how much you took out
then put in what it needs
then see what it says on the dipstick and always use that mark from now on
Sun Jul 19, 2015 6:33 pm
Hello Mike.
I drained the oil out (around half a quart), then put in half a quart to avoid any chance of overfilling the crankcase.
The oil level on the dip stick reads around XX, so it shouldn't be over filled right now. Tried to run the engine again, but it will only turn and not run.
I found another forum post that describes exactly what happened to me before the whole oil-in-airbox issue:
viewtopic.php?f=55&t=26239
Any ideas?
Mon Jul 20, 2015 12:15 pm
around half a quart?
get a measuring container, measure exactly what you take out
and what you put in
cant get any easier then that
find one that does ml
thats the size the list on the engine, so if you get the correct measuring container listed in that then you wont have any guessing
since you mention installing a big bore there are quite a few things that could go wrong
cir clips on piston came off
piston rings not timed correctly
piston ring gap not to spec, I can go on and on
if you followed the service manual when installing, then could be something internal that has gone bad if your not getting any check engine codes
guess you need to do a compression test on the engine should be around 170+ if its all working properly
Mon Jul 20, 2015 2:11 pm
I got the same problem, thank god (s) that Zumike is around and he's down to share the knowledge.
I did check oil level, and seems OK to me.
I just got my Zuma and I'm trying to clean / fix everything I'm capable of. I'm gonna do the oil change with the measuring cup as soon as I get the Yamalube in my mail.
@ManzurGuzmanTattoo
ZUMA125 2014 // WiFi controlled RGB Halo headlights // LED dual headlight conversion
Wed Sep 14, 2016 5:44 pm
a little oil in the air box is normal
the engine crankcase vents into the air box so your bike can take those fumes and burn them through the exhaust
its an emission thing
it collects any oil and drips into that pink or red/clear tube which you empty once in a while
its possible that oil drops make there way to the filter instead of collecting to that tube
the filter if stock, is also oiled from the factory a little
so the oil isn't that bad
but if its covered by a lot of oil then your reducing the air flow which is bad
I recommend using the simota filter sold by drow sports
its like a k&n it can be cleaned and reoiled
keep the drain tube empty
I found the motul oil I use has almost 0% oil residue in my drain tube
my guess is whatever its made of doesn't vaporize as much as xxxxx brand oil does
which then doesn't collect as much in my air box (im still using stock air box too)
but when I used normal cheap oil I would always have some stronge yellow liquid that I needed to drain out every oil change
Wed Sep 14, 2016 6:12 pm
Motul oil uh!? Which one is the one you use?
It wasn't a little bit of oil. Unfortunately I didn't have my phone close to take a picture but that thing had a 1in. pool of oil. once I opened it just started pooring oil all over.
So the drow filter lasts longer? How many times can you clean it before change it?
@ManzurGuzmanTattoo
Wed Sep 14, 2016 7:54 pm
I use motul 5100
as for the simota filter, I didnt put enough miles to clean it
but I figure it could probably go 10,000 without cleaning it
and it looks just like K&N material so you just spray degreaser
wash out with a sink
then barely spray oil on it
should last the lifetime of your bike
I now use the koso filter
dry foam pads
and won't ever clean those either
I don't put enough miles on it probably the foam will rot away before ever needing to change it so I kept the simota just incase that ever happens as a backup filter
Wed Sep 14, 2016 8:15 pm
Hey Zumike what else would you recommend me to look / clean / change ? As I said. I just got this 2014 with 6k miles on it. I'm going thru the service manual and owners manual and it gets a little overwhelming for a total newbie.
I'd appreciate any pointers
@ManzurGuzmanTattoo
Wed Sep 14, 2016 8:25 pm
Users browsing this forum: Google Adsense [Bot] and 6 guests
