View unanswered posts | View active topics It is currently Sat Feb 16, 2019 7:07 am
 OEM contra spring life?
scooters and mods: 09Zuma125,simota a/f,c3 mirrors,red instrmt LED,Koso tail,LV Exhaust,Dr. P var,11g sliders,12t u/g,Polini Bell,Piolt SCs
Post OEM contra spring life?
I've been half assing a search on the life of the OEM contra spring...
Anyone know or recommend how many miles they last? I'm a little over 12K and have been feeling some shuddering above 40 mph...I've had in service for most of the Zuma's life a Polini clutch and evo bell. Still have my OEM spring and think it may be getting spent? Also running Dr. Pulley variator, that could probably use a cleaning...
:cheers:
Thu May 19, 2016 5:58 pm
Post Re: OEM contra spring life?
There are service manuals here on zuma forums. Find the service limit measurement and compare it to your spring. You'll need a caliper to measure it. Springs tend to loose their stiffness over time. If you can't find the specs let me know and I'll look it up at work.
2003 Zuma 70, Dual headlight mod, C3 mirrors, Michelin Boppers, Athena 70 sport, Stage6 19mm Dellorto, Motion Pro throttle cable, Stage6 choke cable (mounted next to key switch), Stock airbox (snorkel removed), stock air filter, Yasuni R exhaust, Malossi Fly 107mm clutch with BLACK Malossi springs, Malossi RED contra spring, Malossi contra spring seat, 2008 rear pulley assembly, stock variator, 4 gram rollers, Still tuning of course.. does it ever end?
Tue Oct 25, 2016 6:08 pm
if its aftermarket you can't go off service manual specs as they all vary in size
they are cheap enough, just replace if you think its getting too soft
I have replaced mine 2 times already
and I have over 12,000 miles
I just replaced as normal maintenance
don't really have a way to check them
personally I like the rrgs 1000 spring
Tue Oct 25, 2016 8:41 pm
I've got a spare OEM I got from a forum member that has low miles on it...I haven't noticed any change in performance but I've got 13K on the Zuma so I wasn't sure about the maintenance on it.
What are some signs that it may need to be replaced?
I recently switched back to the OEM clutch because I could never get rid of the squeal from the Polini clutch. Everything else has been pretty good otherwise.
Thanks for the replies!
Thu Oct 27, 2016 7:08 pm
