2009 Zuma 125 rear axle, wheel, and swing arm help
Got a 2009 Zuma 125 with 12K miles from my brother. It has been sitting up for 3 years. According to him, the reason it was parked was because "the back tire was wobbly. It's missing a spacer and the rim was being ate into." I brought it home , changed the oil, gear oil, put fresh gas in it and jump started it. It fired the first time. I them proceeded to investigate what was going on with the rear. Took the exhaust off, then the swing arm and finally the wheel. Had to shake my head after looking at it. Apparently whoever "worked" on it last did not put all the parts back. Even the axle nut was missing which caused the tire to wobble and the swing arm ate into the wheel. What you see in the picture is exactly how it was when I pulled the tire off. Just a washer and spacer. NOTHING else. I've looked at diagrams online and some list more parts than others. I searched but did not see it here (or on Youtube). Is there a "How To" that breaks down what parts, and in which order, are needed from installing the wheel on the rear axle (spacers, washers, oil seal, etc?)
The Zuma in question.
The swing arm removed. Note the gouging.
The wheel.
There was NO axle nut on it. Once the wheel was removed, the only thing on the axle was a spacer and washer. Pic of just how I found it.
I have been looking for a used wheel and swing arm online. Found a wheel at a good price but when I called it had already sold. Only one listed on Ebay right now and I think the price is too high for it. Three or so swing arms on Ebay. Will pick one up from there. Looks like I need to order several parts to install which is the reason I ask if there is a video available that shows exactly how to install the things needed in the correct order. Thank you for your time.
