They were Working fine just before i Added the Side blinkers usiing the (Green & Brown) Harness from the Previous OEM Blinkers..."Hmmm".. What am i Missing guys...
::Any Suggestions...?? Please... and Thanks
Sun Oct 30, 2016 10:30 am
ZUMIKE
Joined: Fri Jun 25, 2010 6:56 am Posts: 14281 Location: San Diego, CA
Re: HELP:: Rear BLINKERS Not Blinking..
you using led?
or what are you doing
the flasher relay needs to see a certain amount of wattage to make them flash
so if you take away wattage, like replace with led or remove a set of bulbs then they won't flash correctly
2010 Zuma 155cc BWS X Digital Gauges<>Clear Smoke BWS 125 Turn Signal Covers<>Billet Bar Ends<>Front Brake Rotor 260mm<>Razor Cam Covers<>NCY Breather Assembly<>Polini EVO Clutch Bell<>Anodized Orange Dipstick<>RRGS Front and Rear Shocks<>Dual 5000K HID's 35w High/Low Beam<>Black Adjustable Brake levers<>Halo Led's<>TST 2 Stage Variator 9gL 10gS <>NCY Oil Cooler<>Yamaha Skid Plate<>NCY Contra Spring Bearing<>1000 Rpm RRGS Contra Spring<>Yoshimura Exhaust<>NCY Direct Ignition Coil<>Lightweight Cooling Fan<>Koso Cable Clamps<>High Lift Cam+Lightened Cam Sprocket<>Underseat Storage Bag<>Stage 6 (Koso) Clutch<>Accel Handlebars<>Koso Brake Light<>Lightweight Swingarm<>RRGS 4 Pot Caliper (PH80)<>Stainless Braided Brake Line<>Lightened F|ywheel<>OEM Headlight Screens<>Zubiku Wing<>Air Horn<>9 inch stretch<>Koso High Flow Filter/Cover<>RPM 10 Spoke Wheels<>Digital Camo Vinyl Wrap<>SEP Cvt Covers
