View unanswered posts | View active topics It is currently Fri Feb 15, 2019 2:47 pm
Reply to topic  [ 5 posts ]
 Zuma 125 suddenly won't go over 30 mph
Post Zuma 125 suddenly won't go over 30 mph
I have a 2011 Zuma 125 with about 20,000 miles. It's always been well maintained and it's always run perfectly. This week, after riding about 5 miles and stopping at a stop light, it now doesn't go over about 30 mph.
There is no problem starting it. It runs smoothly and apparently normally up to 30 mph. Above 30 it starts to hesitate, then won't go any faster. When I back off to 30 it runs fine again. I have no problem restarting it.
I'm thinking fuel pump: it acts like perhaps the pump doesn't deliver enough fuel. But most of the fuel pump troubles here refer to not starting at all, or failing to start when hot, etc. Other possible causes I've found are a dirty air filter; the belt, rollers, etc in the transmission; the coil; and the fuel injector. The air filter is clean. I will take a look at the belt, rollers, and clutch. But I'm not sure how to diagnose the other things, and I don't want to have to replace those expensive parts one at a time in order to find the problem.
Does anyone have any suggestions? Thanks!
P.S. The Check Engine light is not on.
Sat Aug 19, 2017 9:41 am
Post Re: Zuma 125 suddenly won't go over 30 mph
More info:
The belt and rollers are in good shape.
The compression is okay.
Fresh gas didn't help.
I put in a new spark plug.
The fuel pump runs, though I don't know about the pressure. Any good way to check that?
Is there a way to test the throttle body and all its sensors and fuel injector?
Have ordered a new ignition coil. Will see if that works. I don't want to buy a fuel pump or throttle body unless I have to.
Tue Aug 22, 2017 5:46 am
Post Re: Zuma 125 suddenly won't go over 30 mph: problem found
So I finally got around to checking the valve clearances. These are the two intake valves with a broken rocker arm. Guess this explains a lot: sudden loss of power as in one moment it was good, the next it lost half its power; no fuel injection trouble indicated; no problem found with the ignition; nothing wrong in the transmission. The compression checked out okay -- because the valve is closed.
I can't see the other half of the rocker arm. Hope it isn't damaging something else.
Wed Aug 23, 2017 4:24 pm
I've never seen that. that's impressive. Let us know when you get the head off.
Thu Aug 24, 2017 1:27 pm
well that's a new one.
Fri Aug 25, 2017 5:18 pm
