View unanswered posts | View active topics It is currently Tue Feb 19, 2019 4:34 pm
Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Zuma 125 Fuel Pump Tear Down
Post Re: Zuma 125 Fuel Pump Tear Down
no production dates? well i guess we all have to wait to see if it dies.
for those that did have issues, how many miles did you get before having an issue? perhaps if we've passed that we have made it into the safety zone.
Tue May 18, 2010 2:33 pm
With 3500 miles...I'd say you're safe. Mine had 900 miles when I bought if off the old guy...so not sure when he experienced it, but I'm assuming that's why he traded it back in! I had the problem right away. It's definitely heat related. It ALWAYS starts cold....and will restart right away after a ten minute ride. But if I ride for 30 mins plus....NOT! The pump won't make a noise at all. After a 30 minute cool down...the pump makes it's little noise and the bike fires right back up....ARRGGGG!!! Did get a hold of Yammy dealer -- they said ah yes, a few pumps go out, but no, Yamaha is not doing anything about it and the bike is out of warranty, of course, and they need $100 for a new pump and another $125 to install it. I'm a decent parts replacer...so anyone know how difficult a job it is to remove and install a new pump? :confused:
Thu May 20, 2010 8:02 am
actually the 125 is over 5,500 miles. but if that is the safety zone, then cool. i'd hate to miss out on summer riding for a damn pump.
Thu May 20, 2010 1:27 pm
scooters and mods: Zuma 125
I can't be sure, but it looks like there may be enough room to pull the pump without removing either the tank or the engine, though the service manual shows that the tank should be removed before servicing the fuel pump. The pump is mounted in the same way as in most cars (a bunch of screws around the perimeter of a ring that holds the pump and gasket in place). Drain the tank, unplug the electrical harness and fuel lines, remove and replace.
Thu May 20, 2010 3:00 pm
Welcome to the ZForums !! BITE YOUR TONGUE !! "Maybe you should have bought a Rukus" ... what were you thinking ??
Have you thought about CHARGING the battery really well ... before you take it to the dealership. Good luck with the fuel pump but, we haven't heard about of any faulty ones for quite some time !!
editorwalt wrote:
yeah....just bought my Zuma 125 a week ago from an old man who wasn't truthful I think. Had 900 miles on it and no problems, he said. It starts fine when cold, but once it warms up, it will not restart until it sits for about 30 minutes. You turn on the ign and it cranks, but no fuel pump sound. Once it cools, the fuel pump starts working again (pump sound) and it starts right up. Maybe I should've bought a Rukus?
Looks like others are having the same issue. I'm calling the dealership today to see what they can do about it. :doh:
Yeah, but let me remind everyone that it's been cold 'for quite some time'. I think everyone seemed to think the issue was related to heat. Summer's comin'!!
Thu May 20, 2010 6:09 pm
wow you guys have no room to complain about fuel pumps, (well of course you do but check this out) I've found the zuma pump for just $70 here Boatnjetski Ours for the C3s, mostly the 07s, have the same problems, and list most places for about $300. The cheapest i've found was at the same site for $206. Why the crazy difference????! :wth:
the replacement C3RIDER---- http://scooterfanatic.webs.com
Thu May 20, 2010 11:00 pm
Mine just died at one year old and 4100 miles on her.
Mon May 24, 2010 12:46 pm
Well...my Zuma 125s Fuel pump also went out.
It's now confirmed that my husband did nothing wrong to his.
When the Zuma gets hot, as in the Florida Summer, get ready for the Pump to fail!
Now I have a pump on backorder.
I'll do the work on this one too, so my Zuma is not kicked around a Yamaha dealership for weeks.
Thu Jul 29, 2010 4:30 pm
Amen to that! I'd never let a dealership touch any of my scoots ever again....
Any updates on getting one of the Faulty pumps you got, cut open so we can see what the innerds look like?
Oh and thanks again! This info is always helpful!
Thu Aug 26, 2010 11:55 am
I cut open my husband's fuel pump, I threw mine away.
Basically what it looks like is that the pump must be overheating in one of two ways.
1) The "Filter" that is built into the pump doesn't let enough gas flow through, and thus causes the pump to run faster/hotter to deliver the required fuel.
2) The Fuel Pump is an axial type, with the gas swirling around on the inside of the motor. The tolerances of the internal impeller/armature are too tight. When the impeller/armature heat up and expand, it touches or comes in contact with the magnets that drive the fuel pump causing binding and overheating.
Having all those electrical contacts in the fuel is of course safe since there is no oxygen source or ignition possibiliy in the liquid gas.
Since the filter on the outside of the new pumps looks the same, I think #2 is what is happening.
Thu Aug 26, 2010 12:23 pm
Very interesting - Given your diagnoses and disection, what do you recommend (if anything) as a "Fix" or "Future Concept for a Fuel Pump"
Its obvious, your technical/mechanical ability, so I'm curious as to what you think could possibly be done to prevent this. If the new pumps are the same, then the same scenario can happen over and over.
How can we prevent this?
Thu Aug 26, 2010 12:58 pm
scooters and mods: no scooter anymore!!! dookie got stolen and tossed out the back of a truck, bent frame had to part it out
if i were going to go off the fuel filter theory then this is what i would do. i would find a way to remove the inbound fuel filter as cleanly as possible to take that resistance away from the pump. then i would put an out bound fuel filter some where before the fuel injector. you would be taking the pressure off the intake of the pump and putting it on the outflow. if the notice to scoot not operating right then you could check the filter first before you bought a whole new pump.
not a damn thing!!! dookie got stolen and tossed out of a truck.. bent frame all to hell.. no funds to repair so parted my beast out and now im looking for a used z125 to murder
Thu Aug 26, 2010 1:05 pm
how do you get the internal filter out of a sealed pump without destroying it?
Thu Aug 26, 2010 1:58 pm
not to sure. i have a brand new spare pump just in case the one in my scoot goes out. i can take a look at it when i go over to storage tomorrow. i think there are a couple of lock tabs that you can free up just like on the gas cap. i will check and let you know.
Thu Aug 26, 2010 2:02 pm
Well, interesting idea Will - and it could be a solution.
And thats what we should attempt to reveal here: A Solution.
The current fuel pump design is flawed - how can we improve this (ourselves) to hopefully prevent any future fuel pump issues for others...
Of course, one could hope Yammy would figure this out and redesign - its easier, and more profitable to them - to provide a faulty pump which will incur profits everytime one goes out. So instead of fixing the problem, they treat it like modern medicine. Offering up a pill, you have to buy every month, to keep you alive....instead of offering a cure..
Thu Aug 26, 2010 2:31 pm
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 6 guests
