View unanswered posts | View active topics It is currently Mon Jun 24, 2019 5:26 pm
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 HowTo: Tweaker Blinkers or Led Conversion Signals
scooters and mods: JDM Head Light conversion with HID
Post HowTo: Tweaker Blinkers or Led Conversion Signals
You'll need the following Electronic Relay EP34 I got mine at Oreilly AutoParts on the way home from work.
http://www.oreillyauto.com/site/c/detai ... d=flr758bp
Here is my diagram and corresponding wires to connect it to.
No Diodes needed. =)
note: by adding blade connectors to your extension wires, you can actually plug this into the stock relay harness. no cutting, no hacking, etc... this just works... to each their own on the method they choose to fix their blinkers. This system will work with LED ONLY, REGULAR BULBS ONLY, OR MIXING BOTH into the system. If you want to get crazy you could add a potentiometer in the electronic flasher relay, thus having full control of the flashing times.
How-To: Tweaker Blinkers or Led Conversion Signals -- viewtopic.php?f=57&t=20785
How-To: Painting your plastic panels -- viewtopic.php?f=57&t=20367
Enviromoto Downhill Bar Install / Review -- viewtopic.php?f=54&t=20737
Fri Jun 08, 2012 6:21 pm
Post Re: HowTo: Tweaker Blinkers or Led Conversion Signals
go to radio shack solder a resistor on left and right side to add more load it will get rid of the hyper flash
Fri Jun 08, 2012 10:44 pm
We've got a perfectly good HOW-TO here ::
Actually a few of them.
Old school was the LOAD.RESISTORS
The new ... improved ... no additional load required ... no cross.over blinking fix ... IS THE DIODES !!
Johnny will even sell you a kit to do it (this is best) and he's got a bunch of them ... so you don't have to go and shop at RadioShack ... go and read Johnny's fix for LED lights.
PLEASE !!
Well worth the $$ $$ ... the read ... and the fix ... it's absolutely perfect !!
Sat Jun 09, 2012 4:29 pm
well this method works for me, if i wanted to add to this i'd just add a adjustable resistor directly to the relay. having the option to adjust the flashing relay. Just helping out community.
Sat Jun 09, 2012 9:12 pm
It's a good write-up and gives everyone an option on how to setup their blinkers.
Besides, considering how alot of noobs never search for anything :doh: - yours is at the top of the list. :whip:
:cheers:
Oh-10 Zuma 125
My Gallery: http://www.zumaforums.net/Gallery/v/sloro/
Tge4 wrote:
You guys have officially passed the point of my understanding of this issue/topic.... :patriot:
Sat Jun 09, 2012 11:05 pm
plus no soldering, no cutting wires, etc.. some folks don't feel great about soldering. Also all the connectors can be crimped together, and taken off later if they want to re-sell the scooter stock.
Sun Jun 10, 2012 2:02 pm
scooters and mods: 2012 Zuma 125. Dual headlight mod, rear trunk w/ LED brake light mod, Corbin saddle, C3 mirrors.
Just finished hooking up my LED rear turn signals (thanks Alpinevtec) with a Tridon EP34 electronic flasher that I picked up at AutoZone for $12.99. Install was quick and easy using the same wiring method dem0nk1d describes in his post. The new signals are nice and bright and no more crazy loud clicking from the stock flasher.
~ The most important thing to do when you find yourself in a hole is stop digging.
2012 Zuma 125. Race Concept Smart Man's 155cc BBK, Race Cam, TST Variator, Dr. Pulley Sliders 11gL/13gS, PG Black Exhaust, PG Clutch Bell, 12/40 Gears, NCY Direct Ignition, 1,000RPM Contra Spring, Dual Headlight mod w/ 45W H4's, BWS 125 LED Tail Light, Rear Trunk w/ LED Brake & Turn Signals, LED rear turn signals, Bar end mirrors, Chopped Tail, Duck Bill Rear Fender, Bag Hook, Fairing Basket, 12V socket, Fiamm Blaster Horn.
HID conversions are HIDeous!
https://sites.google.com/site/vanagonheadlightrelays/
Tue Aug 28, 2012 5:09 pm
scooters and mods: 2009 Zuma 155
Your welcome! Lets see some pictures or a vid :D
Yoshimura TRC Carbon Fiber Exhaust,KOSO LED Tail Light,NYC Lightweight Fan,GJMS Speedo Cable Holder,Simota Hi-Flow Filter,NCY Direct Ignition,Magazi Led Signal Mirrors,Embedded LED Rear Signals,GJMS Fan Cover,GJMS Oil Cap,GJMS Rear Stabilizer Bar,GJMS GP-5RT,GJMS Forks,Frando HF2 Radial Caliper w/GJMS Mount,GJMS 260mm Rotor,Swageline SS Braided Line,GJMS Axle Pulleys,GJMS Ti-Coated Front Axle,Accel Bar,Accel Steering Stem,NYC Grips,NYC Throttle Control,GJMS Lever Set,RX1N/PGO Digital Guage,12t Majest Gears,CF Swing Arm,RC 155cc Kit w/2nd gen SRP Injector,High Lift Cam,Aluminium Nikasil Cylinder,Lighter Cam Gear,3D Billet Heat Sinks,3D Cam Breather,BMW e46 HID Projector,Prototype LED Front Signals,CF Parts,TST Varaitor 11g/12g Weights,Ariete Bridgeport Angled Valve Stems,Pirelli Diablo Tires,FRC Torque Drive,PG HD Clutch Bell,HD Clutch,1k Torque Spring,NCY Torque Spring Bearing,KS CNC Floor Board Plugs,Daytona +2mm Kevlar Belt
Mango Tango Build Thread: http://www.zumaforums.net/phpBB3/viewtopic.php?f=50&t=19102
Tue Aug 28, 2012 6:26 pm
Sorry to resurrect this. I replaced the stock relay with the EP34. Positive to brown, Negative to ground and the last one to brown/white. I have the koso afterburners in the rear (regular bulbs) and some LED turn signals in the front. All four signals are blinking. Am I missing a step here?
LiqrSicc's S T R E T C H E D Z155 Build
Wed Sep 05, 2012 10:00 pm
Sounds right ... I just had to go and check the wiring diagram for colors.
LiqrSicc wrote:
EP34.
If this isn't working for you ... why not install the load.resisitors that SOMEONE has already discussed ... a couple of times ??
I'm not familiar with the EP34 (and I did read the specs) ... so I was HOPING that maybe they had internal load.resistors ... or even the diode fix INTERNAL to the EP34.
It sounded so good.
Wed Sep 05, 2012 10:20 pm
It is my perception that a lot of the ZF members try the EP34 solution because of its availability locally at various auto part stores. We live in an instant gratification society and many do not want to msg JohnnyFYX, wait for his response, then paypal him, then wait for their diode kit to arrive…
Just an observation, each to their own. I agree with Bio on this one, get a freakin, flippin Diode Kit from Johnny! D-O-N-E !!!
Oh and let's NOT foget that the Diode kit is less than half the price of the EP34.
Thu Sep 06, 2012 4:47 am
LiqrSicc wrote:
EP34.
It sounded so good.
Yeah, looks like I'll have to go with the resistors.
Thu Sep 06, 2012 7:26 am
I googled Zumaforums, LED, Signal. First thing that popped up was this EP34 post showing it worked so that's what I went by.
Not everybody has as much "scooter time" as you or other members so, yes, convenience plays a big factor.
Thu Sep 06, 2012 7:33 am
most LED Turn signals have diodes built inside of them, so this worked out well for my conversion. Either get the diode kit, or go to rat shack and get some diodes from them.
Thu Sep 06, 2012 8:29 am
I got these cheap turn signals from Amazon. Doesn't look like there's any diodes (other than the LEDs of course) so that may be the issue. Guess I'll order the kit from Johnny and I'll just plug the stock signals back in for the meantime.
Thu Sep 06, 2012 8:58 am
