View unanswered posts | View active topics It is currently Thu Jan 17, 2019 6:52 pm
This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
 *** HOW-TO's STICKY *** All post compiled into one list
scooters and mods: JDM Head Light conversion with HID
Post *** HOW-TO's STICKY *** All post compiled into one list
HOWTO's
updated 08-20-2013
How-to: Installing High Lift Cam -ZUMIKE
viewtopic.php?f=57&t=18072
How-To: Grease/Service the Torque Driver (Rear Pulley) -JohnnyFYX
viewtopic.php?f=57&t=17831
How-To: Tweaker Blinkers or Led Conversion Signals -dem0nk1d
viewtopic.php?f=57&t=20785
How-To: Install Oil Cooler (Integrated Oil Pump Version) -JohnnyFYX
viewtopic.php?f=57&t=19659
How-To: Wiring in a 12v power outlet / GPS install -Yavuz
viewtopic.php?f=57&t=20596
How-To: Prevent 4-Way Flashing When Using LED Turn Signals -JohnnyFYX
viewtopic.php?f=57&t=19625
How-To: BWS Asian HID Projector Headlight Retrofit -JohnnyFYX
viewtopic.php?f=57&t=18360
How-To: lower front forks -hastifc
viewtopic.php?f=57&t=13412
How-To: Removing the rear panels -Shawn
viewtopic.php?f=57&t=5962
How-To: Stebel Horn install -Mista Lyle
viewtopic.php?f=57&t=5891
How-To: Replacing speedometer cluster bulbs with LEDs -IBJanky
viewtopic.php?f=57&t=5972
How-To: Trifecta - Dual HID's, Stebel Horn, Dash Cluster LED's -AlchemX
viewtopic.php?f=57&t=16276
How-To: Y's Motor Town CNC Fork Bottles Installed -johnysmokes
viewtopic.php?f=57&t=18185
How-To: Fuel Pump Replacement -poke it w/ a stick
viewtopic.php?f=57&t=12772
How-To: Oil Leak Fix Cam Chain Tensioner Leak -ZUMIKE
viewtopic.php?f=57&t=17551
How-To: Valve Adjustment -dandydan
viewtopic.php?f=57&t=7600
How-To: NCY torque spring bearing install -Race Concept
viewtopic.php?f=57&t=16564
How-To: Final Gear Install -Electrojake
viewtopic.php?f=57&t=6777
How-To: Removing the Headlight Assembly USA VERSION -Shawn
viewtopic.php?f=57&t=5890
How-To: Easy way to remove anodizing from aluminum parts -ZUMIKE
viewtopic.php?f=57&t=13486
How-To: Change Spark Plug Cap or Shorten Plug Wire Length -JohnnyFYX
viewtopic.php?f=57&t=14413
How-To: Flash2Pass Garage Door Opener Installation -Gyxer
viewtopic.php?f=57&t=14339
How-To: Dual headlights and charge the battery at idle -K-Moe
viewtopic.php?f=57&t=13869
How-To: Removing handguards and keeping blinkers in same position -ZUMIKE
viewtopic.php?f=57&t=13423
How-To: LED Tail Lights Installation / OEM BWS -Shawn
viewtopic.php?f=57&t=5889
How-To: Zuma125 Angel Eyes mod for stock lights -crashguy
viewtopic.php?f=57&t=10473
How-To: Z125 Variator and Clutch mod. -Shawn
viewtopic.php?f=57&t=6187
How-To: Throttle Body and Injector Upgrade -Electrojake
viewtopic.php?f=57&t=10664
How-To: Z125 - LED Blinkers All Around -flateric
viewtopic.php?f=57&t=8017
How-To: Install BWS TDM Head Lights -dandydan
viewtopic.php?f=57&t=7667
How-To: Garmin Zumo GPS Installation -IBJanky
viewtopic.php?f=57&t=6073
How-To: Trunk With Integrated Brake Lights - LED Conversion -Z Geaux
viewtopic.php?f=57&t=7569
How-To: Two Brothers Juice Box Installation -Mista Lyle
viewtopic.php?f=57&t=6786
How-To: Torque spring method -Tge4
viewtopic.php?f=57&t=5162
How-To: Another Dual Headlight Mod Video -Patmon
viewtopic.php?f=57&t=6402
How-To: FI Mapping - K&S Motorsports Installation and Use -Shawn
viewtopic.php?f=57&t=5882
How-To: Painting your plastic panels -dem0nk1d
viewtopic.php?f=57&t=20367
How-To: Repack The Yoshimura TRC Exhaust -JohnnyFYX
viewtopic.php?f=55&t=19375&p=255129&hilit=Yoshimura+pack#p255129
How-To: Install Trunk Mounted 12v Power Socket With USB Charge Adapter -Vandammes
viewtopic.php?f=54&t=17472&hilit=outlet
How-To: Mod Intake Air Box With NCY Intake Pipe For Larger Throttle Body -JohnnyFYX
viewtopic.php?f=54&t=15185&hilit=NCY+Intake+Pipe
How-To: Install Oil Pump (KOSO Hi-Flow Pump or OEM Pump) -JohnnyFYX
viewtopic.php?f=57&t=19833
How-To: Break-In (Bedding) New Brake Pads and/or New Rotor -JohnnyFYX
viewtopic.php?f=57&t=21202
How-To: Zuma 125 Gas Tank Mod <-- Broken Fill Neck -Ho-Train
viewtopic.php?f=54&t=21896
How-To: BWS 125 HID Headlight Retrofit Project (Halo + Devil Eyes) -Ho-Train
viewtopic.php?f=54&t=21981
How-To: Seat mod -- Uncomfortable Seat - No more -mermoto
viewtopic.php?f=54&t=16393
How-To: A General how to - Injector for bbk 155 - lamb123
viewtopic.php?f=57&t=22046
How-To:: How to install a BackOFF XP brake module on the Zuma 125 -Tall Man
viewtopic.php?f=57&t=22108
How-To: NCY Contra Torque Spring Bearing - Video -onekyoung
viewtopic.php?f=54&t=22103
How-To: Mcgyver Zuma 125 Bevertail Reduction -Creeper125
viewtopic.php?f=57&t=22794
How-To: Break your toe at 8 mph on gravel -lambo123 (what not to do ouch!)
viewtopic.php?f=57&t=22891
How-To: DYI mounting bracket for IHOME bluetooth speaker -panaba453
viewtopic.php?f=57&t=22926
How-To: Speedo & Gas Gauge Led Install -ricenoodles
viewtopic.php?f=57&t=22938
How-To: DIY honeycomb cover up (see video) -panaba453
viewtopic.php?f=57&t=22908
How-To: Another DIY project (bag / helmet holder) see the video -panaba453
viewtopic.php?f=57&t=22912
How-To: DYI throttle rocker i made...see video -panaba453
viewtopic.php?f=57&t=22900
How-To: (DIY) home made valve adjustment tool -panaba453
viewtopic.php?f=9&t=22863
How To: 360 degree camera mount for your helmet -ZUMIKE
viewtopic.php?f=57&t=23160
How-To: Silencer X For Yoshimura -ZUMIKE
viewtopic.php?f=57&t=23199
How-To: Clean Throttle Body, ISC Valve, and IAP Sensor -JohnnyFYX
viewtopic.php?f=57&t=23025
How-To: DIY 2nd battery install ( SEE VIDEO ) -panaba453
viewtopic.php?f=57&t=22994
How-To: Radiator hose intake -dem0nk1d
viewtopic.php?f=57&t=23446
How-To: Chop yo seat -dem0nk1d
viewtopic.php?f=57&t=23426
How-To: DCR-MOTOR glove box install -dem0nk1d
viewtopic.php?f=57&t=23748&p=310207#p310207
How-To: Cheap way to lower stock rear shocks -Zumike
viewtopic.php?f=57&t=23851
How-To: Repair NCY Direct Ignition Coil (Broken Spring) -JohnnyFYX
viewtopic.php?f=57&t=24285
How-To: Upgrade the OEM Regulator/Rectifier to a Mosfet R/R-JohnnyFYX
viewtopic.php?f=57&t=24295
Dynamo55b's videos for the illiterate
Spliting the Case Z125 -Dynamo55b
http://www.youtube.com/watch?v=BBrRQZJt ... ature=plcp
Removing Oil Pump -Dynamo55b
http://www.youtube.com/watch?v=h1zOaVk9 ... ature=plcp
Removing the AC Magneto -Dynamo55b
http://www.youtube.com/watch?v=idgpHA8l ... ature=plcp
BBK Install -Dynamo55b
http://www.youtube.com/watch?v=-4dAhQpa ... ature=plcp
Installing the Piston & Cylinder -Dynamo55b
http://www.youtube.com/watch?v=5mDgtGvV ... ature=plcp
Removing Piston -Dynamo55b
http://www.youtube.com/watch?v=kt6ldyly ... ature=plcp
Removing Head & Cylinder -Dynamo55b
http://www.youtube.com/watch?v=3ROtEKDx ... ature=plcp
CVT System -Dynamo55b
http://www.youtube.com/watch?v=YVbdwTRq ... ature=plcp
RDR Rear Shock -Dynamo55b
http://www.youtube.com/watch?v=Mw0h5Jz3 ... ature=plcp
Check Valve Clearance -Dynamo55b
http://www.youtube.com/watch?v=9tD-Gv2D ... ature=plcp
NCY Direct Ign Kit Install -Dynamo55b
http://www.youtube.com/watch?v=35yPwINR ... ature=plcp
Koso Tail Lights -Dynamo55b
http://www.youtube.com/watch?v=GgM9gHuF ... ature=plcp
How-To: Split the Torque Driver and Clutch -Dynamo
viewtopic.php?f=57&t=16242
How-To: TST Variator install -Dynamo
viewtopic.php?f=57&t=15990
How-To: Tweaker Blinkers or Led Conversion Signals -- viewtopic.php?f=57&t=20785
How-To: Painting your plastic panels -- viewtopic.php?f=57&t=20367
Enviromoto Downhill Bar Install / Review -- viewtopic.php?f=54&t=20737
Sat Jun 23, 2012 10:41 pm
Post Re: *** HOW-TO's STICKY *** All post compiled into one list
Out' freaking-standing!
I've been meaning to do this for a long time. Definitely worth a sticky. It will be easy to find even old buried How-to's with the crappy search tool. Planning on adding the authors to aid in cataloging later on, great job. Most of the them are from JohnnyFYX anyways LOL, it might just be easier to search his posts.
Sun Jun 24, 2012 3:21 am
Where is the one about how to sever your finger while removing the front plastics?
Sun Jun 24, 2012 5:45 am
very nice work :cheers:
Sun Jun 24, 2012 5:59 am
OG's, that is a classic
Sun Jun 24, 2012 7:17 am
Updated the links with author names at the end of the title post. Also about the rear panels, let me tell you when i pulled the right side off, that was a f**king knuckle buster. I put a gash in my finger and didn't heal for three weeks. I will suggest next time spraying wd40 or some kind of lube on the rubber grommets. Sheesh the horror just thinking about it. Damn that s**t hurt so bad...
Well since i just went off on a tangent, if anyone finds new post on How-To's or got dropped in the wrong section of the board please post the link here and i will update the main list... Have a good one!
:2bong: :?:
Mon Jun 25, 2012 7:13 am
that be great, so can look at the list and see what's missing then do it.
btw don't forget dynamo's videos, lots of good ones for people who don't like to read.
http://www.rcscooters.com
Mon Jun 25, 2012 7:18 am
Should add that one too. Entertainment LOL
Mon Jun 25, 2012 11:00 am
Dynamo's Center for Kids who Can't Read Good
And who wanna learn to do other stuff good too
Season three!
Mon Jun 25, 2012 11:08 am
Actually, I think you're at the Top Spot for the most How-To's... lol. You're videos are super easy to follow, and I give you mad props for taking the time to record, edit, compile, and upload those videos for everyone in the BWS/Zuma 125 community!
I have a few How-To's that I must have forgot to post in the How-To forum (I think because I didn't intend for them to become how-to's but they just morphed into a How-To. lol. Lemme go find em and I'll compile a list on my next post here. :cheers:
Mon Jun 25, 2012 11:28 am
http://www.zumaforums.net/phpBB3/viewtopic.php?f=57&t=19833
http://www.zumaforums.net/phpBB3/viewtopic.php?f=55&t=19375&p=255129&hilit=Yoshimura+pack#p255129
http://www.zumaforums.net/phpBB3/viewtopic.php?f=54&t=17472&hilit=outlet
http://www.zumaforums.net/phpBB3/viewtopic.php?f=54&t=15185&hilit=NCY+Intake+Pipe
Mon Jun 25, 2012 11:45 am
updated!
Mon Jun 25, 2012 12:27 pm
updated with Dynamo's videos... at the bottom.
Mon Jun 25, 2012 12:48 pm
updated with a few more post. if you see something that's not on here PM ME please
Sun Oct 14, 2012 8:15 pm
Keep'em coming folks...
62 Written How-To's
14 videos from Dynamo's
Wed Apr 17, 2013 6:31 am
