View unanswered posts | View active topics It is currently Sat Jan 20, 2018 9:34 am
 Motorcycle-superstore
Post Motorcycle-superstore
Im giving a free link to Motorcycle-superstore since we get a small percentage of any sales made by people clicking out and making a purchase there.
Heres a Chrome Leo Vince through them for 187+free shipping.
http://www.motorcycle-superstore.com/5/ ... Parts.aspx
Athena 70cc big bore kit:
http://www.motorcycle-superstore.com/5/ ... e-Kit.aspx
High Vis riding gear:
http://www.motorcycle-superstore.com/13 ... ighVizGear
Michelin Reggae dual sport tires:
http://www.motorcycle-superstore.com/5/ ... -Tire.aspx
Michelin Bopper street tires:
http://www.motorcycle-superstore.com/5/ ... =SLIsearch
Sun Oct 09, 2011 1:49 pm
Post Re: Motorcycle-superstore
Pirelli sl26 tires:
Pirelli sl60:
http://www.motorcycle-superstore.com/5/ ... irelliSl60
Sun Oct 09, 2011 6:47 pm
Yuasa Maintenance Free Battery
http://www.motorcycle-superstore.com/5/37/453/28180/DPITEM/Scooter-Batteries-Yuasa-Maintenance-Free-Battery.aspx
Western Power Sports Sealed Battery
http://www.motorcycle-superstore.com/5/37/453/28407/DPITEM/Scooter-Batteries-Western-Power-Sports-Sealed-Battery.aspx
2001 ZUMAII - Tires TBD
Sun Oct 16, 2011 8:36 am
I didn't think to look here and have ordered a bunch of stuff from them. Been loving how freakin' fast I get my stuff, 2-3 days from ordering and it's at my door. Wish they carried more scooter goodies. :)
So some links are in order for future use. (If the kickdown is still in effect) :)
LeoVince TT (Best price I've found for those looking for one)
http://www.motorcycle-superstore.com/5/ ... map=206977
Shinko SR426 Dual Sport tires. My new fave tire, even though I'm grinding through the rears pretty fast, I think that just my bad hard braking habits scuffing the rear alot...... But cruising at 35 on loose gravel and feeling stable makes them worth it, plus they corner on pavement like a dream. Proly a really soft compound.
_______________________________________
The Rumrunner:
'09 Zuma 50.
Top Performance Trophy 70cc, Stage6 small end bearing, 2005 carb needle raised one notch, Malossi carbon reeds, 84 main jet from Yamaha, Throttle mod, LeoVince TT, Polini Speed Contol variator (#241-301), Hoca Racing drive face, 7g adige sliders, Malossi yellow torque spring, dual headlight mod, triple brake light mod with LEDs, LED plate light, less bulbous turn signals, 12v power port, Air horn, RAM GPS mount, 15W fork oil, Shinko SR 426 4 ply Dual Sport tires, Ducted trans cooling with a fan up under the cowling so I can still ride through mud.
Build thread: viewtopic.php?f=50&t=19720
Mon Jun 11, 2012 9:37 am
I have bought all my Pirelli SL26 tires from thm as well as some other items. Good prices and fast dependable service.
08 zuma 50cc
T-mod.
Mon Jun 11, 2012 1:48 pm
I've naught 4 sets of tires from them, nothing but great service from them.
Sat Jun 23, 2012 4:35 am
