Page 1 of 1
[ 5 posts ] |
You are looking for a part ? Ask Scoot-tuning.com
Author |
Message |
Scoot-tuning.com
As mentioned in other post. We are now able to offer you free shipping. We have a wide range of products for most scooters. Shipment of parts is made from our U.S warehouse.
We have all the biggest brands: Stage 6, Malossi, Polini, STR8, etc. Top Performance.
Feel free to make your request, one of our representative will respond as soon as possible.
_________________ www.scoot-tuning.com NOW FREE SHIPPING TO U.S on order over 100$. Standard U.S rate are apply on order under 100$
Wed May 15, 2013 8:51 am |
butters
Joined: Thu May 23, 2013 3:32 pm Posts: 36 Location: sw wisconsin
 Re: You are looking for a part ? Ask Scoot-tuning.com
Yeah good prices but take week to even ship parts after paid for.
_________________ 2004 BWS Athen 70cc BBK, S6 HPC crank, leo vince zxr, Dello 19mm black, motion pro cable/pulltube, motoforce manifold, S6 R/T Oversized CVT kit, Koso Clutch, Koso DB-01R Cluster, Premixing, Boppers, Headlight mod,Front signals relocated,rear signal mod, blacked out plastics, polished case/cover
Fri May 24, 2013 5:00 pm |
Nick Batzdorf
Joined: Tue Jul 08, 2008 9:16 pm Posts: 11362 Location: Los Angeles area
So my post from the other day showing a 20-odd dollar shipping charge for a $10 torsion controller was just because you haven't updated your website to show free shipping yet?
_________________ '05 Zuma 50, Athena sport 70cc (12mm piston) with Polini head (.9 squish), B9ES spark plug; timing advanced about 2˚; Yasuni C16 exhaust, Buzzetti kick stand to make room for it (and Stage6 paddock stand after dropping the freaking bike because of the kick stand); stock airbox no snorkel, 5 x 1/2" holes; Stage6 21mm racing PHBG, 45/95/W7 1 lean/40 slide; Polini/Power One 12mm HPC crank; Athena 15/50 gears (also have 14/42s pressed into a gearbox cover, just switched back and like the 15/50s so far); 107mm Malossi Delta clutch, "racing" red springs/lighter "racing" counterweights ± 6800 RPM engagement, Stage6 Kupplungsglocke (bell - the light one); Malossi 6112811 Overrange kit, red contra and 28.2G rollers; VForce 3 reeds; Michelin Bopper tires; back to the stock shock; dual headlight wiring; C3 mirrors; Trailtech TTO tachometer and temp gauge.
Fri May 24, 2013 5:59 pm |
specalk
Joined: Sun Aug 03, 2008 4:57 pm Posts: 1007 Location: USA
Got a 2005 oem zuma50 motor
_________________ MY 2000 PREBUG PHOTOS -----> viewtopic.php?f=50&t=25587
Fri Jun 14, 2013 1:52 pm |
extreme
Joined: Sat May 11, 2013 4:06 pm Posts: 45 Location: Sumter SC
I have spent alot of money with u guys, but now going to scooter attack and paying that shipping cause it only takes a week or less!, tired of waiting weeks and months to get my parts from you all!
_________________ 2009 zuma=Polini Evo 2 L/C ,Stage 6 R/T crank,MKII intake with Vforce 3 reeds,Malossi overange pack with stage 6 torque control clutch,MVT inner rotor ignition,Str8 naked bars and bar stem, Adelin brake levers(adjustable!)Stage 6 all in one speedo,tach,temp,etc Aerox 100 rims powdercoated black(thx specalk!)Stage 6 quick action throttle and switch unit,Str8 extreme cut water pump cover w/stage 6 pump, Stage 6 R/T front forks and 4 piston brake caliper 2008 zuma=bored over once Leo vince pipe(ZX)Athena variator,Michelin bopper tires 2001 Aprilia SR50(minarelli L/C!)=under construction,stage 6 95cc big bore new engine cases !!,44mm 90mm con rod R/T crank!!,Malossi overange Malossi inner rotor, str8 naked bars, 4 piston caliper, 260mm rotor,stage 6 rear shock,str8 xtrem cut side cover and h20 pump
Thu Sep 26, 2013 8:03 am |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
