View unanswered posts | View active topics It is currently Sat Jan 20, 2018 9:45 am
Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Zuma 125 Stretch's 9 inch
Post Zuma 125 Stretch's 9 inch
Not trying to reinvent the stretch
but modified what I like from others out there and also at the same time trying to keep the cost down
as they are pretty expensive
Ive been testing this design on my bike for a while now
The ones im selling are even stronger then the one im using and mine is still holding up great
Features
9 inches long
I think im the only one to integrate the stock license plate mount into the rear shock adapter
so you actually have a way to mount the plate
Its also tucked up high enough not to hit the fender or get crushed in a large hole
but then it all depends on your suspension
my bike is lowered compared to using stock zuma shocks and I still have like 1 inch clearance from hitting the fender when compressed all the way down
2 adjustable rods on each side
Will take away any wheel cant you may or may not get with the other stretches that only have one non adjustable rod
Plus you can change the engine height or suspension height
I try to keep it same as stock, the angle of the engine
This way you can still read your dipstick and have the same suspension geometry
You can keep the stock air box too
Also keep most of the under seat storage, I can still fit a 1 gallon gas can under the seat and then some if you take your time and cut the underseat carefully
I will supply all hardware to install
You may or may not need extended Throttle cables but I would purchase the extended Brake cable off ebay
Look for this one usually $10 shipped
https://www.google.com/search?q=84.7%22+Rear+Brake+Cable+For+150cc+200cc+250cc+Moped+Scooter+Taotao+Roketa+Honda&ie=utf-8&oe=utf-8
This will work too but twice as much
http://www.ruckhouse.com/index.php/homepage-products/87-extended-brake-cable.html
If you need throttle cable I got mine here but you can use the stock throttle cable if you have stock bars or shorter then stock
http://japan.webike.net/products/2075153.html
They will come powdercoated black, with stainless hardware
Im asking $470 shipped USA only
Sun Feb 16, 2014 6:51 pm
Post Re: Zuma 125 Stretch's Low Price
Features
9 inches long
Look for this one
84.7" Rear Brake Cable For 150cc 200cc 250cc Moped Scooter Taotao Roketa Honda
Just picked these up from the welder, I still need to paint everything
Im asking $380 shipped
More pics to come once they are painted
Can you make on for zuma 50
2000 zuma, orange, dr evo 70 cc, 100 main jet leovince zx pipe for after break in period.
TNT bars/stem , custom gauge, TNT rear lights. Custom front lights
Sun Feb 16, 2014 7:35 pm
Looks awesome dude
L/C Bidalot 86cc, Bidalot 44mm stroke crank, TPR 86cc Big Bore Pipe,Trenched and Ported Cases, MVT DD19 Iggy, Vforce 3 reed block with cf reeds, 10mm/5degree reed Spacer, Malossi Overrange (21g total weight), Malossi Yellow Contra, Keihin 28mm carb, UNI air filter, Doppler 14/42, Dr.Pulley HIT Clutch ( 8000 rpm engagement ), Stage6 433 R/T clutch bell, Premix 32-1.
MXS Race 70cc, 28mm PWK , S6 Big Valve, SR-1 Crank, Most Wicked Pipe....
Sun Feb 16, 2014 9:24 pm
Nicest Zuma stretch of any kind I've seen to date.
x2 on the 50. I don't like the disjointed look most stretches give, yours looks better.
Sun Feb 16, 2014 10:41 pm
Here is what the finished product will look like
Mon Feb 17, 2014 2:04 pm
Looks great! I will PM you when I get the $$
Wed Feb 19, 2014 12:54 pm
Sat Feb 22, 2014 10:07 pm
For those that purchase my stretch and need the kickstand foot welded on
As you will need to cut it shorter for the bike to lean over properly I will do that for free
Just chop the foot pad off and cut the leg to the level you want
Mail me all the parts and I will weld it up
And if it's disassembled enough I can powdercoat it glossy black or whatever color you want that I have in stock
Tue Feb 25, 2014 7:11 pm
So what additional parts do you need to get that you don't provide IN ORDER to install this and are not provided with your kit? I am sure I and all others would like to know. Is it ready to install right out the box and go riding when I receive it from you? How much total cost will these extra parts be?
2005 Zuma-MKII Race, MKII 21MM PHBG 40/92, C16, 12mm Crank, B9HS/LBO5EP 5K Cap, Advanced Timing, +1 Ignition Coil, Premix 32:1, Derestricted Intake, VF3's, MHR OverRange Complete, 27 grams, MHR Delta Clutch, MHR Wing Bell, Red Contra, Blue Springs, Torsion Controller, 15/50 upgears (SOON 14/42), Oversize Fan, Snork removed, Start Block Off Plate, Throttle Cable and Single Pull Tube, Dual Headlight Mod, Integrated Rear Signals, Boppers, Tach/Temp Gauge, kickstand.
I GOT MACHETES AND SWORDS FOR ALL YOU FAGGOTS THAT ROAR....Image
Wed Feb 26, 2014 12:07 am
Fri Apr 18, 2014 7:39 am
I heard billet!
:cheers:
How-To: Tweaker Blinkers or Led Conversion Signals -- viewtopic.php?f=57&t=20785
How-To: Painting your plastic panels -- viewtopic.php?f=57&t=20367
Enviromoto Downhill Bar Install / Review -- viewtopic.php?f=54&t=20737
Fri Apr 18, 2014 7:29 pm
dont need billet here , standard steel works just fine , payment at the ready
Tue Apr 29, 2014 1:09 pm
billet is easier to make
as a machine does the entire stretch
where hand welded is more labor
since I personally dont make these im trying to get the best price for me, so I can get the best price for you all
I want to have the cheapest cost stretch available, which hopefully one day will lower all the other prices
this works out good for everyone
you can still buy composimo steel stretch for around $500
or steady garage for around the same cost or more cant remember
that will be aluminum
Tue Apr 29, 2014 1:31 pm
looks like the next batch will be steel again
should start them soon
I have an email list of people wanting some too but as we all know most will probably back out
so im only going to make 3 as it costs alot out of my pocket to get them made
I will take preorders but be aware its not going to be ready right away
but if you want one for sure just pm me I can do it at a lower price
I will post updates once they start to actually get made
Then I still have alot to do on my end too
Tue Apr 29, 2014 3:53 pm
Back in stock
Fri May 23, 2014 5:49 pm
