View unanswered posts | View active topics It is currently Sun May 20, 2018 3:03 am
Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 DrowSports- Parts
Post DrowSports- Parts
Limited Time FREE Shipping for all Zumaforums Memebers in North America
Drowsports Auto-lube Block off Plate (Zuma 50/Grand Axis)
Cost: $10.00
The factory Auto-lube Pump is useless after a Cylinder Kit upgrade. This plate will help you cover up the hole after you remove you Auto-lube Pump.
Drowsports Starter Delete Plate (Zuma 50/Grand Axis)
Cost: $10.99
Option: Line-grain Black Hard Anodized or Line-grain only
Drowsports Starter Delete Plate will offer you a clean way to remove your factory Zuma/GA starter. This aluminum Starter Delete Plate was line grain and hard anodized for a more durable finish. (Hardware is included)
All item will ship via USPS.
If your interested please PM me.
DROWsports
DROWsports Facebook
Tue Jun 16, 2009 11:29 pm
Post Re: DrowSports- Parts
DROWsports Zuma 125 Brakes Caliper Bracket will soon be available Black and Clear anodize.
This Zuma 125 Bracket from DROWsports Bracket is design to reposition the stock caliper to clear the 260mm Brake Rotor that we offer.
Drew
DROWsports
DROWsports Facebook
Tue Aug 10, 2010 9:49 pm
We have the Zuma 125 Brakes available.
DROWsports Black Caliper Bracket
DROWsports Silver Caliper Bracket
DROWsports
DROWsports Facebook
Wed Aug 25, 2010 12:40 am
johnysmokes wrote:
Any pictures of the RPM rotor installed? I'm about to pull the trigger, but can't decide if I want the black bracket or the raw (silver). :)
Here you go, i just took pictures of both black and silver. I have a different stye rotor on.
Silver Zuma Brake Bracket
Black Zuma Brake Bracket
DerHahn wrote:
got any 4 piston caliper upgrades to go with the rotor?
Sorry no 4 Piston caliper yet.
DROWsports
DROWsports Facebook
Wed Aug 25, 2010 1:51 pm
I did some testing today. The Polini Torque Spring does fit but it was a little tighter then stock. One side of the spring fit better then the other. I rode around for about 3 miles and everything seem ok. I had an dip in my acceleration around 10-18 mph and it seem like the Polini Torque Spring got rid of that.
I also test the RRGS Torque Spring that came with my RRGS Variator and i didn't like it. It seem like that Polini respond better off the line. I want to do a little more riding to be sure. The RRGS Torque Spring seems like it wants heavier rollers.
The only mods i have on my Zuma 125 is my RRGS Variator with 10gr. rollers and a Two Brother Exhaust.
I hope this helps.
Drew
DROWsports
DROWsports Facebook
Sat Sep 18, 2010 4:21 pm
Just got in.
RPM BWS Wheels
RPM BWS 260mm Rotor
BWS125 Headlights
RRGS Variator BWS125
RRGS Clutch Bell BWS125
RRGS Throttle Tube
RRGS Axle Spool
RRGS BWS125 Fork
Koso Handlebar Billet Clamp BWS125
Koso Handlebar Grip
Koso BWS125 Clutch
Accel Handle Bar
Ruckus Intake Manifold PC20 Carb
Black Mirrors
and more.....
DROWsports
DROWsports Facebook
Wed Nov 03, 2010 1:23 pm
http://www.facebook.com/photo.php?fbid= ... 2135727799
We are working on loading parts to our site.
Drew
DROWsports
DROWsports Facebook
Thu Nov 04, 2010 6:37 pm
muskydave wrote:
Are you guys working on any new brake rotors and brackets for the zuma 50? Your 125 version is the cheapest I have seen and would love one for my 50.
Dave
Hey Dave,
That is on our to do list.
Check out DROWsports Zuma125 Parts like this RRGS Brake Lever.
DROWsports
DROWsports Facebook
Thu Nov 11, 2010 3:05 pm
Drow Sports is now a U.S. Authorized Dealer of BCD-Design. For more BCD-Design Parts please check out DROWsports.com
BCD-Engineering Carbon Fiber 22.2mm Handlebar
BCD-Engineering Billet CNC Handlebar Stem for Yamaha Zuma
DROWsports
DROWsports Facebook
Fri Dec 17, 2010 12:36 pm
BCD Design Kick Starter :q:
DROWsports
DROWsports Facebook
Thu Dec 30, 2010 1:57 am
Hey Guys,
Just got in a new shipment. Parts ready for purchase on drowsports.com soon.
KOSO 32mm Throttle Body and Intake Manifold for Zuma125
KOSO Zuma125 LED Tail LIght with Signals
KOSO Zuma125 Racing Clutch
KOSO Brake Cable Bracket
KOSO Motor Oil Temp Sender Adapter
RRGS Silver Forks for Zuma125
RRGS Rear Shocks Zuma125
Check out DROWsports for more Yamaha Zuma125 Parts
Drew
DROWsports
DROWsports Facebook
Tue Feb 22, 2011 2:29 pm
Parts Now Available:
Yamaha Zuma125 KOSO 32mm Throttle Body
KOSO Yamaha Zuma125 LED Tail Light
KOSO Brake Cable Holder
:patriot:
DROWsports
DROWsports Facebook
Fri Feb 25, 2011 10:01 pm
New Zuma125 parts available at DROWsports!
BWS125 LED Tail Light Cover
BWS125 LED Headlight Cover
RRGS Zuma125 Lower Forks
RRGS Transmission Final Oil Filler Cap
Look out for more products:
DREW
DROWsports
DROWsports Facebook
Fri Jun 24, 2011 11:48 am
DROWsports
DROWsports Facebook
Fri Jun 24, 2011 1:09 pm
New DROWsports parts for Zuma 125, made from dry carbon fiber.
It should be available in a few weeks.
Drew
DROWsports
DROWsports Facebook
Thu Sep 08, 2011 8:08 pm
