View unanswered posts | View active topics It is currently Wed Jan 16, 2019 8:35 pm
Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4
 Aerox 100 wheels
Post Re: Aerox 100 wheels
Brain fart. I meant wheels. :)
Tue Mar 04, 2014 5:55 pm
scooters and mods: Tp 70cc,next r,vforce 3 reed block,s6 variator,stock carb 86 mj,vee rubber 119c tires,med contra,stiff clutch springs
I got ya. Aerox wheels are 13 inches vs zumas 10 inches. Also there's way more options for different brake set ups.
Tue Mar 04, 2014 6:14 pm
Okay, so they are also like upgears. That's what I thought. Thanks.
What do you have to do to make room?
Tue Mar 04, 2014 8:02 pm
Get rid of the centerstand for openers, right?
Tue Mar 04, 2014 8:05 pm
No there not bigger, the tires just have a smaller side wall. My rear tire is a little wider but has the same diameter as a stock sized zuma tire. The front is maybe 2% bigger in overall diameter then stock.
Tue Mar 04, 2014 9:26 pm
And now I remember asking this before and getting the same answer - for some weird reason.
Okay, thanks.
Tue Mar 04, 2014 10:33 pm
Thought I'd do an update on this thread...
The wheels, brakes, forks and hub are all working great. The biggest improvement are definitely the tires. I had boppers before witch were a great upgrade from the OEM junk. But these Pirelli Evo's are on a different level! For any of you guys with aerox wheels and need new skins, get the Pirelli evo 21/22 tires you won't be disappointed.
Fri Apr 25, 2014 10:17 pm
I got a set shop might be selling
Sun May 14, 2017 2:49 pm
Sorry to revive an old thread but did you use an aerox spacer or cut down yours and if so what size did you end up using??....also did the smaller rotor(the one that didnt look right) line up properly? I am just doing this install and was not anticipating this rotor issue ..it looks like a 180mm flat rotor with 70mm bolt centers and 58mm hub center would fit without modification. I would also need ,I believe, M10 bolts instead of M8 for the rotor?
Wed May 09, 2018 9:40 pm
