View unanswered posts | View active topics It is currently Tue Oct 23, 2018 2:24 pm
Reply to topic  [ 10 posts ]
 WTB Ignition and Key
Post WTB Ignition and Key
Lost my Key when I moved to my new apartment, Need a new ignition and key set... Sent to 49546
Sat Apr 30, 2016 6:01 am
Post Re: WTB Ignition and Key
For what kind of scooter?
Pull the ignition switch out of the bike and bring it to a locksmith. They'll charge you about 50 dollars to make a key for it.
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Sat Apr 30, 2016 7:36 pm
You might also want to check out ebay. Sometimes ignition and key kits pop up there.
2003 Zuma
(tuning)
Stage6 HPC 10mm crank
Malossi MHR Overrange (24.3g)
Malossi 107mm MHR Wing Bell
Malossi Yellow Contra Spring
Malossi Torsion Controller
RFY Shock
Stage 6 F1 Mirrors
Stage 6 14/42s
NGK BR9HS
Michelin Boppers
Trail Tech Vapor
LEDGlow Underglow Kit
Sun May 01, 2016 7:36 pm
scooters and mods: Zuma 70cc Athena
If anyone has one, I'd be needing one as well. Found out tonight mine is bad.
2005 Yamaha Zuma Athena 70cc, Midnight Black, stock exhaust, 82 MJ, Michelin Bopper tires, NCY 107mm performance clutch & NCY performance clutch bell, Athena 15/50 helicals // "LEROY"
2005 Yamaha Zuma Athena 70cc, Midnight Black, stock exhaust 84 Main Jet, // the $250 scoot, with 23,000 miles!
2008 Yamaha Zuma, Blue Metallic, Athena 70 sport, Leo Vince ZX-R (soon to be installed), Dellorto 19mm, Stage 6 choke
Mon May 23, 2016 7:45 pm
There's one on ebay right now for 45 dollars
http://www.ebay.com/itm/YAMAHA-BWS-ZUMA ... ea&vxp=mtr
2008 Zuma 50
2012 Zuma 50 (sold)
Mon May 23, 2016 8:21 pm
With shipping not bad $15 less than partzilla.
Mon May 23, 2016 9:06 pm
Tell me this, are these repairable? The problem is I'm not getting continuity when the key is "ON" and therefore nothing works. If I remember right, the heads were like shaved off so you couldn't get inside it easily.
Tue May 24, 2016 6:01 am
scooters and mods: 2003 Zuma (parts bike) 2004 Zuma Basket case rescue. Motoritec 70bbk, 5.7g Doppler rollers, Uni filter, Michelin Boppers
I bought the one from eBay. Works perfect, cheapest I found too.
Tue May 24, 2016 10:23 am
They are, but just take a dremel with a cut off wheel and make slots for a standard screw driver.
2008 Zuma 50
2012 Zuma 50 (sold)
Tue May 24, 2016 4:14 pm
I got 1 for sale
Sat Jun 11, 2016 4:43 am
