Page 1 of 1
[ 3 posts ] |
WANTED: Yasuni C16 (minarelli)
Author |
Message |
Spaz12
Joined: Fri Feb 15, 2013 7:55 pm Posts: 1515 Location: Las Vegas, NV
Anyone have one?
I suppose a City 16 will work if you have one of those instead.
_________________ (Unfinished)2005 Zuma 50 W/ Aerox LC motor Malossi MHR Big Bore 77 LC, Malossi RHQ crank, Roost 86 pipe, 28mm Keihin PWK Carb, Stage6 reverse intake manifold, Custom Subframe, Stage6 Vforce3 reed valve, Polini open air Filter, Malossi 2010 Over Range, Polini 2G clutch, Dr Pulley clutch bell, Malossi yellow contra. Aerox wheels. ProTaper bars. Buzzeti side stand. Many more upgrades to come...
2008 Zuma 50 2012 Zuma 50 (sold) 2006 Metropolitan selling/parting out! 2003 Derbi Red Bullet
Sun May 15, 2016 4:44 pm |
turbotype1
 Re: WANTED: Yasuni C16 (minarelli)
_________________ 05 Zuma: Stage6 70cc Sport Pro MKII,Stage6 12mmHPC crank,Stage6 MKII intake, MKII 21mm Dellorto;95mj-45pj,Stock airbox; snorkel out(2) 3/4 holes,Adj-Inj pump;yellow cover,Stage6 Choke cable w/my own aluminum lever(plastic one broke before I even rode the scoot),YMS pipe ,Stock variator;4.0 rollers,Stock belt, NCY TD ; pins in 40 degree slots, Stage6 medium contra,Stage6 MKII 107mm clutch; orange springs adjusted-tight,all weights in each shoe,Stage6 R/T 433 Bell,15/50 up- gears , Aerox wheels and forks,Aerox front fender, Stage6 280mm front brake....
Tue May 17, 2016 7:36 am |
Spaz12
Getting it for someone else so trying to keep the costs down if we can. Thanks though Turbo
Tue May 17, 2016 2:24 pm |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
