View unanswered posts | View active topics It is currently Mon Mar 18, 2019 9:12 pm
 LED halo rings and strips
Post LED halo rings and strips
http://www.ebay.com/itm/282049415072
Came across with that kit and was guessing if anyone tried the RGB controls/app already.
http://www.ebay.com/itm/281900645304
There's few vendors offering Bluetooth, WiFi, or IR controls.
@ManzurGuzmanTattoo
ZUMA125 2014 // WiFi controlled RGB Halo headlights // LED dual headlight conversion
Wed Sep 14, 2016 7:21 pm
Post Re: LED halo rings and strips
I install halo rings in the zumas, and ruckus
I've found what I think are the best looking rings
you can't see any led it looks like the entire rings glows
the ones you posted may have tiny spaces when they are on, maybe seen more in daylight
but then they do change color which is cool
if you choose single color rings
you can safely stack 3 rings inside
before worrying about the light butb ruining closer rings from heat
I've also installed rgb strips under bikes
I use the ones that have a rgb every 1/4 inch or so
makes a super bright light, and can't spot any gaps when it reflects light on the ground
where cheaper rgb could have lights every inch or so
and does show that when using them
the phone switching colors I guess is cool
but how practical is it to use
you can get kits that come with cheap IR remotes that can cycle almost every color possible too
and play different functions
for like $20 you can get the 16 foot strip rgb weatherproof and the remote and controller
I have seen similar looking remote for the cheaper rgb halo rings too
but I just couldn't risk buying them and not looking good when I know what I like to use is super bright, super colorful and very nice looking
Wed Sep 14, 2016 8:11 pm
