View unanswered posts | View active topics It is currently Thu Mar 21, 2019 1:17 am
 SO CAL 2 STROKE RIDERS CREW
scooters and mods: currently building.....
Post SO CAL 2 STROKE RIDERS CREW
I know we got our die hard 2 stroke riders out there of all styles. Let yourself be known. Los Angeles and immediate surrounding areas.....
2005 Zuma-MKII Race, MKII 21MM PHBG 40/92, C16, 12mm Crank, B9HS/LBO5EP 5K Cap, Advanced Timing, +1 Ignition Coil, Premix 32:1, Derestricted Intake, VF3's, MHR OverRange Complete, 27 grams, MHR Delta Clutch, MHR Wing Bell, Red Contra, Blue Springs, Torsion Controller, 15/50 upgears (SOON 14/42), Oversize Fan, Snork removed, Start Block Off Plate, Throttle Cable and Single Pull Tube, Dual Headlight Mod, Integrated Rear Signals, Boppers, Tach/Temp Gauge, kickstand.
I GOT MACHETES AND SWORDS FOR ALL YOU FAGGOTS THAT ROAR....Image
Tue Apr 22, 2014 11:21 am
Post Re: SO CAL 2 STROKE RIDERS CREW
U gotta check out the 2-stroke extravaganza in September Vapz.....fumes galore! Lol! :D
Tue Apr 22, 2014 12:57 pm
scooters and mods: *2002 yamaha vino classic*
:cheers:
c-kell wrote:
''The Thrilla Of The Villa""
2002 Yamaha Vino Classic S
Engine mods:
Motoforce Evo crank Stage 6 Streetrace kit Dellorto 17.5 man choke
Polini carbon fiber reeds. Gianelli shot exhaust
CVT mods:
Polini Variator. Hebo Driveface. Malossi Winged Clutch Bell. Stage 6 clutch springs
Suspension:
RDR Nitrogen Filled Shock (rear)
Frame:
Home fabricated 6" stretch 2" lower
ZF member #14
Sat Sep 06, 2014 2:48 pm
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Sat Sep 06, 2014 2:54 pm
