View unanswered posts | View active topics It is currently Sat Sep 21, 2019 11:21 pm
 MICHIGAN?
scooters and mods: 2004 Zuma Grey, Polini cast iron sport 70, 6g rollers, stage 6 clutch bell, adige 3 shoe 107mm clutch, Michelin regge...
Post MICHIGAN?
Any riders around
04 Yamaha Zuma 9***mi
UNDER CONSTRUCTION....Polini Sport 70(25**mi+),Stock Crank,Adige 3 Shoe 107MM Clutch, Stage6 r/t 107mm bell, highway bars, 6G Malossi Rollers, Kevlar Belt( had two left over) , 19mm Dellorto PHBG Race Carb W/ S6 Choke, Polini Team 3 Exhaust, Uni Filter(Stock Air Box Snorkel Removed), Cf Reeds(Stock cage), Regge Tires, Black 05 Rims, EBC Breaks F/R,Duel Headlight, R Fender Downsize...Add & Fix As I Go....Need Help Please,Anyone & Local MI Area Would Be Good
Winter14/spring15 project for 04 zuma- s6 or polini crank, bigger better better top end Still deciding, and go from there... crank case paint? New hoses wiring every piece top to bottom
WTB: 88-2000 PREBUG
05 Yamaha Zuma R.I.P-Had Good Times
Fri May 23, 2014 5:22 pm
scooters and mods: 2009 Zuma 125
Post Re: MICHIGAN?
I just moved to Bridgman, MI...
Mon May 26, 2014 10:16 am
Profile YIM
Post Re: MICHIGAN?
Where's that at
WTB: 88-2000 PREBUG
Mon May 26, 2014 10:25 am
Post Re: MICHIGAN?
About an hour southwest of Kalamazoo near the MI/IN border
Sat May 31, 2014 4:00 pm
Profile YIM
Post Re: MICHIGAN?
Oh ok I know were that is now
WTB: 88-2000 PREBUG
Sat May 31, 2014 4:17 pm
Post Re: MICHIGAN?
Any groups or clubs around lansing mi
2004 Zuma 50 (10,600MI) - Poilini 70cc Cast Iron. 19 Dellorto Phbg Ds (94,45,60,W7 2nd From Bottom Clip). Polini Team 3 Pipe. S6 Choke. Motion Pro Thtottle/Cable. Mollossi CF Reeds (Unkmown Thickness).7G Rollers(Maybe 8G), Stage6 MKII Clutch(1500 Spring, White S6 Clutch Clutch Springs +1 Copper Weight Per Shoe) .S6 Rt Bell. Nhrc 220 Big Brake. Sb Brake Line. Koso Tach. Tt Temp. Highway Bars. Stock Airbox W/Uni Replacement Filter & Snorkel Out. Progrips, Mollossi Rs1 Rear Shock (FS),RRGS Rear Brake Arm & Axle Puller, Battery Tender Hardwired
Sat Apr 11, 2015 11:18 pm
Post Re: MICHIGAN?
FScott lives around you.
Sat Apr 11, 2015 11:51 pm
Post Re: MICHIGAN?
I know he helps me once and a while just looking what else is around also
Sat Apr 11, 2015 11:54 pm
Post Re: MICHIGAN?
Gotcha :)
Sun Apr 12, 2015 12:00 am
Post Re: MICHIGAN?
Try the Lets Get Together, Great Lakes board on Total Ruckus http://totalruckus.com/phpBB3/viewforum.php?f=187
Wed Apr 15, 2015 8:20 am
