View unanswered posts | View active topics It is currently Sat Jan 19, 2019 4:08 pm
Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Prime1010's Kymco Super 9 LC
Post Prime1010's Kymco Super 9 LC
Just bought my second scooter. 2002 Kymco Super 9 LC. Only has 1,700 miles with the last 50 miles on an Airsal 70cc kit. Also has some kind of Tecnigas pipe installed. Anyone know which pipe this is?
    Liquid cooled
    Rear disc brake
    Dual piston front caliper
    Tachometer on dash
    Inverted front fork
    Nice looking scooter
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Malossi Sport 70cc BBK - Stage6 PRO Exhaust - Dellorto PHVA 17.5mm 92MJ, 34Idle, A12 Needle Up One Position, Snorkel Removed - Athena Primary Drive Gear - Nology Hotwire - Malossi Reed Cage - Malossi Multivar - Stage6 Rollers 30g - Malossi Delta Clutch - Malossi Wing Clutch Bell - Malossi Torsion Controller - Malossi Yellow Contra - Motoforce Racing R6 Rear Shock - Slipstreamer Windshield - Dual Headlight - Triple Brake light - EMGO Trunk - Ram-Mount for GPS
Wed Apr 20, 2011 6:05 pm
scooters and mods: 02 stock Zuma...05 radical Zuma racebike...
Post Re: Prime1010's Kymco Super 9 LC
Wow...liquid cooled...AND better brakes than a Zuma? I like.
Wed Apr 20, 2011 6:29 pm
Found out that the pipe is an old Tecnigas Next.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Thu Apr 21, 2011 7:25 am
Here's a short video of the Super 9 on my way to work this morning. Clutch engages way too low and weights need to be lighter.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Thu Apr 21, 2011 11:19 am
I have a question. Does anyone know what motor this is a clone of? Is it the same as the Piaggio Zip and Gilera Runner?
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Fri Apr 22, 2011 6:09 pm
Thats an interesting question. Maybe pop over to http://scooterinvasion.net/forum/ there are a couple guys building them there that would probly be a pretty big help.
Fri Apr 22, 2011 6:16 pm
images are not showing up Prime - lets see this beast?
Fri Apr 22, 2011 8:11 pm
Yeah, the site I hosted them at is down right now. Here's a mirror.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Fri Apr 22, 2011 9:05 pm
Could you do a little review for us? Maybe compare the 9 and the Zuma?
Fri Apr 22, 2011 10:59 pm
I strapped the GoPro to a friend yesterday and had him ride behind me on his DR 400 SM. This video shows some boggy take-offs and a high-speed run up-hill against the wind that indicated 56MPH on his speedometer.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Fri Apr 29, 2011 7:39 am
Not bad! How do you like it overall? Rides drives well? Brakes.....forks...shock?
Fri Apr 29, 2011 10:23 pm
Its a minarelli clone, but they have slightly different head designs and exhaust, you would not be able to put a minarelli exhaust on a stock cylinder but if you swapped our a minarelli cylinder it will need to be slightly modified.
Sat Apr 30, 2011 12:05 pm
Here's a nice review written by someone else with tons of information about the Super 9
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Wed May 18, 2011 11:00 am
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Sun Aug 14, 2011 3:37 pm
scooters and mods: 00' prebug-70cc bbk-Tecnigas trek-30g rollers-Dellorto 17.5mm-CF reeds-Polini 13/44 gears-Yellow spring-Pirelli SL26's
Looks very similar to the Sym Orbit's setup..
2000 prebug-Polini Sports kit 70cc BBK-Stage6 Street Exhaust-4.3g rollers-Dellorto PHVA 17.5mm 82Mj- Fibreglass reeds-Polini 13/44 gears-Stage 6 Medium clutch/contra springs with torsion controller-IRC MB99's-C3 Mirrors-Demon Indicators-Modified 35w/35w H4 Headlight-Custom Leather Seat-Oversized Fan-Custom Paint Job
1993 Derestricted Jog
2008 Sym Orbit 80 4T- Unrestricted Cdi-Naraku HS Vario-Racing Cam
Sun Aug 14, 2011 11:35 pm
