View unanswered posts | View active topics It is currently Mon Feb 19, 2018 10:36 pm
 Eton Beamer II - 100cc Jog Engine Swap
Post Eton Beamer II - 100cc Jog Engine Swap
This looks very tempting. Does anyone know anything about this 100cc Jog engine? What kind of pipe would fit it best?
http://kansascity.craigslist.org/mcy/2832132628.html
Code:
I have an Eton Beamer II for sale. It is in pretty good condition. For those of you who don't know this is a Yamaha Zuma clone. Like the Zuma It is a two-stroke, which is faster and simpler than it's four stroke counterpart. This scooter has some nice parts on it. It has a scrappydogs 100cc Yamaha Jog engine/tranny powering it. It has, front disc brakes, a performance CDI module and a performance coil. I also purchased a battery last season for it. I have had this scooter going 50mph on the flats and 55 downhills (I weigh 190lbs). This is GPS verified and not going by the speedo (not accurate) as most people on craigslist advertise. The reason why the price is so cheap is because it CURRENTLY DOES NOT RUN. It will only need a carb cleaning to get it started as I have not started it since August. Then it will need something brake related in the rear as the tire in the back seems to be catching the rear drum, then it will be 100%. The motor alone was $450 so I am taking a huge loss on this scooter. I am asking $600 so if you're interested please only text me @ 816 286 9670. Pick up only.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Malossi Sport 70cc BBK - Stage6 PRO Exhaust - Dellorto PHVA 17.5mm 92MJ, 34Idle, A12 Needle Up One Position, Snorkel Removed - Athena Primary Drive Gear - Nology Hotwire - Malossi Reed Cage - Malossi Multivar - Stage6 Rollers 30g - Malossi Delta Clutch - Malossi Wing Clutch Bell - Malossi Torsion Controller - Malossi Yellow Contra - Motoforce Racing R6 Rear Shock - Slipstreamer Windshield - Dual Headlight - Triple Brake light - EMGO Trunk - Ram-Mount for GPS
Fri Feb 03, 2012 7:54 am
Post Re: Eton Beamer II - 100cc Jog Engine Swap
well some of scrappydogs engine were pos and wolndt running when new and they looked like used engines instead of new engines
as for a pipe its going to depend upon if its the 90 or 100 cc engine
but the best bang for your buck is proably a phonager
or to have 190 mech over on si or 49 cc scoot make you a pipe
i am going to have him make a pipe for my build with that athena crank and a 54 mm jug
Fri Feb 03, 2012 8:10 am
