View unanswered posts | View active topics It is currently Sat Jan 19, 2019 4:02 pm
Reply to topic  [ 9 posts ]
 My next scooter
Post My next scooter
http://www.wired.com/autopia/2013/09/bm ... deid-86001
Fri Sep 20, 2013 10:54 pm
Post Re: My next scooter
:wth: BMW electric??? Very nice!! :cheers:
Sat Sep 21, 2013 12:50 am
http://www.wired.com/autopia/2013/03/ktm-e-speed/
This will run circles around that.
Sat Sep 21, 2013 6:12 am
what's the weight of this?
Sat Sep 21, 2013 7:19 am
Photo-Shoped, deisel oil pan & a morphed bike. Arnold would Approve!
Sat Sep 21, 2013 11:37 am
The KTM looks like a nice scooter, but it does 40 miles on a charge and tops out at 50MPH.
Meanwhile:
"BMW rates the electric motor at 11 kW — or 15 horsepower [same as the KTM] — with a temporary boost to 47 HP and an impressive 53 pound-feet of torque when you twist the grip. Range is rated at over 60 miles in mixed riding, with a 0-60 MPH time of 6.2 seconds, and the ability to top up the pack from zero to full in four hours using a 220-volt outlet."
I suspect that the BMW is far more expensive too. Not only is it a BMW, it has heated grips, ABS brakes...it looks like a pretty serious toy.
Actually, the 60 mile range - which you probably want to take with a grain of salt, like every other spec - is not enough for an expensive bike. Most likely the one to buy will be the second generation.
Sat Sep 21, 2013 11:49 am
I'm wondering if you'll have any difficulty in tuning that scoot ??
Sat Sep 21, 2013 1:39 pm
Sat Sep 21, 2013 1:42 pm
would work great for my commute, but still wouldn't get one and wouldn't leave town if i had one.
gas up the zuma and go 200 miles or so. :D
after i the tank work is done anyway.
Sat Sep 21, 2013 3:10 pm
