View unanswered posts | View active topics It is currently Sun Feb 17, 2019 3:36 pm
Reply to topic  [ 8 posts ]
 Water Repellent
Post Water Repellent
I have a pair of gloves that I really like. The only problem is that they weren't water repellent. As a matter of fact they soaked up water like a sponge. I tried several different silicone based products with no success. Than I ran across this stuff at WalMart in the shoe department.
It's Camp Dry Performance Fabric Protector by KIWI. According to the can it's a polymer. It works great. Two warnings:
  1. Make sure you get the Camp Dry Fabric Protector, not the Camp Dry Heavy Duty Water Repellent.
  2. DO NOT USE IT INDOORS!! The fumes are intense.
It says you can even use it on suede and Gore-Tex.
KIWI website here;
http://www.kiwicampdry.com/products.html
Happy New Year! :toot:
It is better to travel well than to arrive.
The Buddha
Sat Jan 02, 2010 3:52 pm
Post Re: Water Repellent
Thanks Old Guy! I've been looking for something like this.... Gabe :patriot:
2007 Yamaha C3 Scooter 600 miles
2007 Yamaha C3 Scooter 14,000 miles
2010 Ural T Motorcycle - R/H shifter 7,000km
1980 Kawasaki KZ 250 ltd 3,500 miles
"You never need a loaded weapon, until you need one very badly!" SFC Hugh Lispcomb - Senior Drill Instructor - "Charlie, 4-2" Ft.Leonard Wood, Mo April 1974
Mon Jan 11, 2010 1:59 pm
scooters and mods: stock
thanks for info, i will try.
Sun May 08, 2011 6:21 pm
Gonna have try this stuff out. Save me from having to get some new gloves. :) Plus it'll come in handy for the camping kit.
_______________________________________
The Rumrunner:
'09 Zuma 50.
Top Performance Trophy 70cc, Stage6 small end bearing, 2005 carb needle raised one notch, Malossi carbon reeds, 84 main jet from Yamaha, Throttle mod, LeoVince TT, Polini Speed Contol variator (#241-301), Hoca Racing drive face, 7g adige sliders, Malossi yellow torque spring, dual headlight mod, triple brake light mod with LEDs, LED plate light, less bulbous turn signals, 12v power port, Air horn, RAM GPS mount, 15W fork oil, Shinko SR 426 4 ply Dual Sport tires, Ducted trans cooling with a fan up under the cowling so I can still ride through mud.
Build thread: viewtopic.php?f=50&t=19720
Sun May 08, 2011 8:49 pm
scooters and mods: 2003 Yamaha Zuma Dual Headlight Mod
Camp Dry is great stuff. We used it on our camping gear when I was in Boy Scouts. Always stayed nice and dry inside the tents, even in the heaviest downpours.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
Stage6 WingCooler bell
Malossi white contra
C3 Mirrors
Stage6 CNC brake levers
JDM Fender With Clear Lenses
MORE COMING SOON!!
My Zuma
ChuckD420's 2003 Zuma
Sun May 08, 2011 11:30 pm
May I ask... WHY ??
Oldguy wrote:
warning ::
Mon May 09, 2011 6:19 am
May I ask... WHY ??
Oldguy wrote:
warning ::
If I recall correctly (Remember, I started this thread over a year ago.) the Camp Dry Heavy Duty Water Repellent is just silicone and doesn't work as well and makes everything slippery.
The Buddha
Mon May 09, 2011 6:57 am
Thanks, OG ... I was just curious why I wouldn't want the HeavyDuty stuff.
Mon May 09, 2011 7:09 am
