View unanswered posts | View active topics It is currently Sun May 20, 2018 8:44 am
Reply to topic  [ 13 posts ]
 The quest for Ice Water
Post The quest for Ice Water
After riding around in 3 figure temperatures today I didnt get sweaty, but I did get thirsty.
So the problem that I'm facing (I didnt have it last year...) is how do you drink out of a bottle with a full face helmet on? My idea so far is to take a water bottle (dasani 20oz or that size bottle) Drill a hole in the cap, and put a straw (the kind with the bendy tips) through the hole. Then put some silicone around that to seal.
What say you?
(The reason I didnt have the problem last year is that I was wearing a half helmet. Honestly though, when its 3 figure (over 100) temperature wind blowing on your face its cooler to wear a FF. I am probably going to get a tinted visor though, the clear one lets heat through the front)
2005 Zuma 50, Under construction
Mon Apr 20, 2009 4:28 pm
Post Re: The quest for Ice Water
Best solution, get a Camelbak water hydration system. http://www.camelbak.com/index.cfm I have a few of these and use them on everything from Biking, ATV riding, Motocross, Jet Skiing and anything else where I need to be hydrated. You just fill the bag with your favorite beverage and put it on like a back pack. Then when you get thirsty just put the hose up under your helmet and bang instant refreshment. If you don't have one of these then I highly suggest one.
Mon Apr 20, 2009 5:55 pm
hydration pack +1. must have.
2005 Zuma "StarScream"
Mon Apr 20, 2009 7:10 pm
Great, idea. can you get those things with a built in backpack? I may need to be able to use a backpack, in which case I coudl see that interfering.
Also, it's not for long haul stuff. Just cruising around in town. How much are those things...? less than $20?
Mon Apr 20, 2009 7:41 pm
Hyazuma
Current Configuration:
3. NGK BR7HS
6. Malossi Delta Clutch
9. Malossi Up-Gears
13. Arreche 19mm Carburetor
14. Arreche Manual Choke
Mon Apr 20, 2009 7:47 pm
Hyazuma wrote:
Hyazuma
Great idea, but remember no open bottles/cans of alcohol
Mon Apr 20, 2009 7:50 pm
I couldn't find one with Bawls in it :)
Hya
3. NGK BR7HS
9. Malossi Up-Gears
Mon Apr 20, 2009 7:53 pm
Hya
Aha!, thats what I'm doing. Thank you Hya :bang:
Mon Apr 20, 2009 7:55 pm
conez0 wrote:
Great, idea. can you get those things with a built in backpack? I may need to be able to use a backpack, in which case I could see that interfering.
They do make them with small and large back packs. They can be a little pricey but well worth the $$$. Check out their site :http://www.camelbak.com/index.cfm
Mon Apr 20, 2009 7:58 pm
you can also just buy the bladder. Throw some ice in and throw it in with the rest of your stuff in your backpack and call it good. platypus makes a very versatile bladder if you do any backpacking in addition to riding. Compacts super small when empty.
Tue Apr 21, 2009 12:02 am
I thought about this today coming home from the dealership. Then I remembered I bought a Military Camelbak.
If you want a cheap solution, and dont mind waiting a bit here is what I did. I sniped a military backpack styled camelback like this for around $12 bucks with shipping.
http://www.alleghenyoutlet.com/alleghen ... tion-1.jpg
Yes, you can get them that cheap but get the bag used, then buy the bladder hose, and bite valve separately. Mine was intentionally bought for a bug out bag and for hiking but now I am glad I got the one I got for durability purposes. Bladders for them are $10 from China. Takes about 2 weeks or 10 -14 business days to get it usually.
So for about $22 you can have a military spec camelbak. Which is a steal since if you bailed with it on, chances are its still going to work fine. But lets hope none of us actually have to follow up on that one.
Miscreants, rogues, scoundrels, misfits and villains under 250cc look no further
Representing the 636 and 314 areas without apology
2012 Yamaha Zuma 125cc - Say YES to 666!
Thu Sep 20, 2012 8:55 pm
OK ... you wouldn't want to just use the cupholder and take an 8 oz. beverage ??
How much does that camelback hold and what are you going to put in it ... WATER !!
Myself ( since we last thought about of this one 3 1/2 years ago ) ... I'll carry a BOTA BAG !!
Maybe two.
Thu Sep 20, 2012 9:45 pm
My camelbak will hold 3L. I think 100oz. But like I said, I didnt intentionally buy it for scooterr use, it was for a 3 day Bug out Bag. (which its only part of the liquids I would be carrying.)
The solution I had by far is the cheapest for durability reasons, unless you can find something else friends. I know the ACU camo isnt pretty to most, but the stool is solid. Built like a tank. Ill be using mine when the weather permits it. Getting cold around my parts. Winter is coming.
Mon Sep 24, 2012 12:24 am
