View unanswered posts | View active topics It is currently Wed Aug 21, 2019 4:56 am
Reply to topic  [ 99 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 ChuckD420's 2003 Zuma
scooters and mods: 2003 Yamaha Zuma Dual Headlight Mod
Post ChuckD420's 2003 Zuma
This is my 2003 Zuma, that I bought for $300 at the end of june this year. Had 279 miles on it when I got it and now has a little over 1,500 miles. So far I've taken both of the reflectors of the front(one was already busted from where the previous owner laid it down), took off the front fender and the little mudflap on the back, took both passenger footrests off(wasn't trying to pay almost $50 each to replace them), took off the stickers on the side covers, did the dual headlight mod, and installed a Leo Vince ZX with the included springs and the 3/3 weight combo. I've had the speedo pegged on a flat a few times since I put the pipe on, no GPS though, so not sure what the exact top speed is.
Sorry about the poor quality of the pics.
Once I get the money I plan to install:
70cc Polini Corsa BBK
aftermarket HPC crankshaft (haven't decided which one yet)
19mm carb
aftermarket variator
Yasuni pipe (not sure which one would be best with this BBK)
JDM taillight
Pirelli SL26s
I would also like to do the naked handlebar conversion and new gauge setup soon and get aerox wheels for it. The wheels would probably be last since it's gonna cost a bit.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
Stage6 WingCooler bell
Malossi white contra
C3 Mirrors
Stage6 CNC brake levers
JDM Fender With Clear Lenses
MORE COMING SOON!!
My Zuma
Fri Oct 01, 2010 1:42 pm
Post Re: ChuckD420's 2003 Zuma
Would love to see video of the speedo pegged on flat ground, or by pegged you mean at 40mph
Fri Oct 01, 2010 4:20 pm
The needle will actually round out a little past 40mph. I might try to get some video of it this weekend.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Fri Oct 01, 2010 9:05 pm
scooters and mods: 2008 ZUMA YW50
Typically "pegged" means as far as it will go in the speedo...so the bottom corner, well past 40mph, is "pegged". 40 is just the biggest number they put on the guage.
2001 ZUMAII - Tires TBD
Sat Oct 02, 2010 4:06 am
thats why there is no way a stock 50 engine/carb/tranny can peg the gauge, maybe 40-41 but thats about it on flat ground unless the speedo is way off, but the gps can confirm
Sat Oct 02, 2010 8:29 am
Sorry about the confusion guys, I had no idea the needle went that far past 40mph. I'm still gonna try to get a top speed vid this weekend, let's see how far past 40mph I can get the needle to go. I always back off once I hit just past 40, because I don't want to get pulled over, so I'm not sure how fast I can actually go.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Sat Oct 02, 2010 9:47 am
scooters and mods: '08 Zuma, '99 Zuma
My '08 with the stock bore would easily go faster than 41 after I installed the ZX, but the '08 and up have taller gearing, and can go faster than the '02-'05 models.
Sat Oct 02, 2010 4:43 pm
Well, I shot some video of some top speed runs this weekend, I made these attempts on a stretch of road probably an 1/8 mile long. It was pretty bumpy and there was a heavy crosswind, so I wasn't able to get it all the way up to speed. I'll try again next weekend if the winds aren't as strong. I also need to figure out a way to mount my camera so I don't have to hold the damn thing while I do this, that's a PITA.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Mon Oct 04, 2010 2:14 pm
scooters and mods: 2008 ZUMA YW50XL
I just did the carb mod to my stock 08' Zuma, and can reach 40-mph+. I took my son for a ride and surprisingly we still hit 40-mph.
Sun Oct 17, 2010 1:18 pm
You can hit 40mph riding two up? how long does it take?
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Sun Oct 17, 2010 1:31 pm
I'll have to get back to you on that. I guess it didn't feel like it took that long. maybe a city block.
Sun Oct 17, 2010 2:15 pm
It took us 3 tenths of a mile to hit 40 mph flat road little wind, two up. Thats with a stock 08' the only thing we have did to it has been the carb mod.
Sun Oct 17, 2010 5:00 pm
Update
I've repainted my ZX flat black Rustoleum BBQ & Stove paint. While I had the pipe off I took the badge off the silencer and turned it around so you can't see the rivets (I left them, because I did,t want to have holes in it.) I stripped the paint off the bracket, and just left it bare, since it's aluminum and shouldn't rust. Also got my clear taillight lenses put on my JDM fender, along with the LED bulbs for the taillight and turn signals.
I will post a vid of the lights at night once it gets dark here.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Sun Apr 17, 2011 5:28 pm
those taillights look really good with the silver paint
why do the zumas (american) have the speedo so close to the top speed? the bws (canadian) speedos go up to 80 km/h which is 50mph
STOCK ZUMA 50CC PARTS FOR SALE
buguy wrote:
A tool??!! We ride scooters...we all look like tools dude!
cathy_liebchen wrote:
Fast, Cheap, Reliable = Choose any 2. Can't have all 3
Sun Apr 17, 2011 5:57 pm
Thanks. I'm not sure about the speedo, but it would be nice to have it read higher, that way you would know how fast you were going.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Sun Apr 17, 2011 6:06 pm
Users browsing this forum: OlegPechepeg and 1 guest
