View unanswered posts | View active topics It is currently Sat Sep 14, 2019 11:11 pm
Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Just wanted to show my mockup
scooters and mods: '09 Zuma, '05 Pipe, Malossi cast iron BBK, Stage6 V-Force reed block w/ CF, BCD Stem, BGM Drag bars, Koso LCD Speedo
Post Just wanted to show my mockup
I mocked up my stretch last night and drew the brackets up. I'm cutting them out today and hopefully welding them in this weekend.
photo by BLanigan747, on Flickr
http://www.zumaforums.net/phpBB3/viewtopic.php?f=9&t=22001
Thu Oct 04, 2012 9:17 am
scooters and mods: 2006 Yami BWS, Stage 6 Street Race 70cc,Malossi Multivar Variator
Post Re: Just wanted to show my mockup
So how did it turn out?
Any more pics?
2006 Yamaha BW
Stage 6 Street Race
Mallossi Multivar variator w/7gram rollers
Motoforce three shoe clutch
dual headlamp mod
C3 mirrors
rear amber turn signal lens mod
Michelin Reggae front
Kenda rear
Thu Oct 04, 2012 7:24 pm
So I got it together and running Friday night around 10 so heres the first pic while out on its first cruise:
Untitled by BLanigan747, on Flickr
A better daytime pic:
My goofy butt on it:
I'm super happy how it came out. I stretched it 8" and lowered the motor mount about 1.5" This winter I need to pull it apart and paint the frame.
Sun Oct 07, 2012 6:44 pm
scooters and mods: 09 Zuma Completly stock except for Stage 6 street exhaust...TunR Handle bars and stem...
looks good do you have any pics of the mount or how you did it?
2009 Zuma Blacked out
Hurricane stretch kit
Stage 6 Street Exhaust
TunR Handlebars
Koso db-01r Digital Guage
2012 50F Handlebar Stem
Trusty Levers
Michelin Boppers
Blinker Mod
Mudflap Delete
52.4mph Flat Road
_My Build_ viewtopic.php?f=3&t=21872
Mon Oct 08, 2012 12:49 am
I dont right now. Ill pull some panels and take some pics today.
Mon Oct 08, 2012 3:35 am
Looks smooooth duder. Smooth... very pimp.
2009 Zuma 164 cc - Ported head, 28mm TB, oil cooler ( Race concepts: http://www.facebook.com/RCscooters?fref=ts ) , (Average 70 mpg * est) Top speed ( 70 speedo tucked in any weather.) , Mutt Muffler and tst variator, PG clutch, rrgs 1000 rpm spring, png bell. Daytona belt. 12/39 gears 10/12 rollers.
Mon Oct 08, 2012 10:42 am
WOW, that is exactly what I would like to see mine look like!!!
Would save me buying a Ruckus. This looks better!!!
I would appreciate more pics as well.
You said youlowered the mount 1.5". How'd you do that part?
Was the stretch seperate from the lowering of the mount?
Did you have to relocate the top shock mount?
Cant wait for more pics.
2006 Yamaha BW
Stage 6 Street Race
dual headlamp mod
C3 mirrors
Kenda rear
Mon Oct 08, 2012 1:45 pm
The lowering was incorporated into the mount when i made it longer. i basically set the scooter on the ground with the stock mount and measured 8" back and 1.5" up and made the new plates to mount it there. I ended up welding the bracket directly to the frame but I have a couple friends that want me to do their zumas so I stripped my wife's zuma down to the frame so i can redesign my extension so it will bolt on using the original rubber mounts. I made a new shock mount on the frame. I got super lucky when i made the mount as i built it with the intention of having to cut the left side plastic for it but it fit without any cutting. Im going ot go out to the garage now and take a few pics for you guys.
Mon Oct 08, 2012 5:36 pm
Cant wait to see the pics.
Keep this post up to date, PLEASE.
I have a feeling there are a lot more out there that would love to do this mod but need help.
A bolt on mount would be the best.
2006 Yamaha BW
Stage 6 Street Race
dual headlamp mod
C3 mirrors
Kenda rear
Mon Oct 08, 2012 6:10 pm
Just a couple pics of it sitting pretty:
Heres the wifes all torn down:
Heres what the stock mount looks like:
And heres what mine now looks like:
The shock it close but i didnt have to cut the plastics:
I had to cut a little of the trunk:
But with the foam tray no ones the wiser:
I relocated the coil rather than get a longer plug wire:
Heres everything with the panel off . I welded the shock mount right to the tail end of the frame under where the studs for the fuel tank are. i used box tubing because it slid right into the c shape of the frame and was the right width for the shock mount:
Here you can see I welded my mounts to the frame. my plan on Mk2 is to use the original rubber dampener mounts as you feel more of the engine vibration when it welded:
Mon Oct 08, 2012 6:22 pm
Oh and I lowered the engine mount because i wanted to get the back end nice and low without tipping the engine too far forwards.
Mon Oct 08, 2012 6:25 pm
forgot this side shot:
and t looks so little from standing height:
Im going to strip it down this winter and paint the frame as well.
Thank you guys for the compliments. I'm really hoping to make this capable of being a bolt on kit. If I do you guys will know it and I will make them available.
Mon Oct 08, 2012 6:29 pm
looks really good im in the process of figureing out what imma do for my stretch...i think im gonna go with the hurricane kit from japan.webike. i like how it comes with all the correct cables and extension wires needed..i just wish i new someone that used the hurricane kit so i could have more info on it just cant find anyone....did you lower the front at all?
TunR Handlebars
Trusty Levers
Michelin Boppers
Blinker Mod
Mudflap Delete
52.4mph Flat Road
Mon Oct 08, 2012 11:38 pm
scooters and mods: 2009 Zuma 50cc 2stroke
Very nice, Can you put a list of parts with part numbers and were purchase, like the brake lines throttle cable etc. I like to stretch mine thank you really appreciate it. :)
[url]Image[/url] [url]Image[/url]
Tue Oct 09, 2012 12:52 am
I lowered the front a little by cutting some of the coils out of the springs. I may look into lowering it some more now that the back is down.
For cables etc. I did the Stem and Bars setup and Stage6 billet controls. The Stage6 kit came with a throttle cable that is plenty long. The only wire that wont reach in stock form is the plug wire. As I showed in the picture I decided to move the coil mount back to allow me to use the stock wire but that was just my preference, A new wire would be possible and probably easier. I don't have the rear brake cable hooked up yet and I haven't checked its reach with the stretch because I don't have a lever, but it had plenty of length prior to stretching it so I should be all set there.
Tue Oct 09, 2012 4:01 am
Users browsing this forum: VincentWen and 1 guest
