View unanswered posts | View active topics It is currently Thu Apr 25, 2019 7:11 pm
Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Need help asap. Vino only goes up to 40 mph.!!!!!
Post Need help asap. Vino only goes up to 40 mph.!!!!!
So after a 45 ride with my friend, on the way back home my Vino 125 tops out at 40 mph. I didn't hit any potholes or other objects on the road. I also noticed my pick up is slower than usual. I'm new to scooters and any help is greatly appreciated. Vino only has about 1,000 miles if that. What are some of the things I should check that could cause this problem??
Mon Aug 04, 2008 8:01 pm
Post Re: Need help asap. Vino only goes up to 40 mph.!!!!!
Maybe the clutch is hot and you are experiencing clutch fade.
2004 Honda Interceptor • 2013 Honda PCX 150
Mon Aug 04, 2008 8:05 pm
scooters and mods: 1998 Zuma (Stock) 2002 Zuma (Stock)
Is this an 08 Vino?
What year? Are you sure it is a 125???
If this is an 08 Vino with only 1000 miles.... take it to the dealer ASAP.
Tue Aug 05, 2008 6:36 am
scooters and mods: 2008 Zuma 50
too bad OG is not here. he was the Vino expert..
2008 Murdered Out Zuma
My Zuma Gallery
T-modDual HeadlightsTriple Brake LightsFlawless' DIY Dash Mounted ClockC3 Mirrors
Tue Aug 05, 2008 7:09 am
i see you posted this same thread at scootertime...
as they said... tire pressure???
Tue Aug 05, 2008 7:25 am
I highly doubt tire pressure will slow u down so much. i'm sure u could tell its tire pressure . u'd be wobbling all over the road
prob its ur ail intake came loose and ur engine is not getting the right amount of air..
or something else..
My Zuma Gallery
Tue Aug 05, 2008 7:47 am
yea, I also posted this on scootertime and provo as well. Imma look over all the things that was discussed and hopefully it shouldn't be anything big or serious. Well, the Vino was purchased used from private seller so I dont think warranty still exist. :doh:
Tue Aug 05, 2008 11:43 am
is it an 08 or not??? if it's not been over a year since purchase you have warranty regardless of if it was purchased used... :doh:
Tue Aug 05, 2008 11:49 am
good one.
Tue Aug 05, 2008 5:35 pm
scooters and mods: Vino 125
Partially true. The warranty does transfer BUT the "warranty transfer papers" need to be signed. This rarely happens rendering the warranty useless. :doh:
08 Vino 125
15,200 miles and riding...
Wed Aug 13, 2008 9:19 pm
the paper for the warranty says you have 10 days to have it inspected by the dealer... i need to do that with my wife's used Vino ASAP!!! :wth:
Thu Aug 14, 2008 5:43 am
when I got my 07 Vino it would not go past 40 for the first 300 miles or so by the time I got 1K miles on it, I was able to get 55-60 out of it
Tue May 26, 2009 10:46 pm
Really??? I took mine on a test run from the dealer with only 3 miles on it. I told him I wouldn't buy it unless it did atleast 55...well it did. 10,000 miles later I can hit 60 on flats no problem...still stock.
08 Vino 125
Wed Jul 15, 2009 10:56 pm
I got mine used a few weeks ago and it only has 527 miles on it and will get up to 63mph. Almost time for that first oil change. Love it, but usually only ride between 45 and 50mph. It's an 08.
Sun May 23, 2010 10:12 am
Lolz. Buuuullshit! That ornary guy learned from me. Lolz'z.
Zuma 125: Malossi Vari, 8g rollers, 1500rpm torque spring, NCY adjustable clutch, BTX air intake, Group Racing gas shocks, Yoshimura CF exhaust, Vertical headlights, Corbin seat, Stretch kit.
Fri Oct 15, 2010 11:06 pm
Users browsing this forum: Google [Bot] and 3 guests
