View unanswered posts | View active topics It is currently Wed Sep 18, 2019 2:48 am
 YAMAHA PREBUG ZUMA BUILD
Post YAMAHA PREBUG ZUMA BUILD
I POWDER COATED MY ZUMA ENGINE CASES AND PRESSED IN NEW
BEARINGS AND SEALS. I ALSO HAD TO
MACHINE THE INSIDE OF HE CVT CASE FOR
THE POLINI EVOLUTION OVERRANGE CVT TO FIT THE PREBUG ZUMA CASES.
https://www.scootertuning.ca/en/variato ... ramic.html
Oversize CVT Polini Evolution 3 (Ceramic) Model: PACKPOLCER
Rear Pulley Polini Speed Drive Evo 3 Ceramic Model: 244.0579
https://www.scootertuning.ca/en/variato ... ution.html
Variator Polini Hi-speed Evolution 2016 (13mm) Model: 241.727
Mon Jul 16, 2018 6:28 pm
Post Re: YAMAHA PREBUG ZUMA BUILD
https://www.scootertuning.ca/en/subfram ... tical.html
Swing Arm Engine Brace Polini Torsen WD (Minarelli Vertical)
Model: 172.0014
$119.00
The extreme forces associated with tuned engines often place other components under too higher load. The boomerang shape of the TORSEN WD, inspired by the world of MotoGP, gives additional support to the engine block, thereby reducing irregular movement or asymmetric tyre wear. This swing arm also offers greater stability that can be felt in any corner. Note: The TORSEN WD swingarm works only with Polini exhaust systems, if the system is from the Big Evolution range, For Race 2 and Scooter Team.
This fits the prebug zuma no issues. The crappy deal is the polini evo pipe fits way to tight. I’m going to ceramic coat the pipe black and powder coat the arm gloss black.
Mon Jul 16, 2018 6:45 pm
Post YAMAHA ZUMA PREBUG REAR SHOCK 250MM
THIS IS A SHOCK I GOT FOR THE PREBUG ZUMA 250MM. FITS AND LOOKS GREAT, WHILE I DO NOT HAVE THE STOCK AIR BOX OR STOCK CARB IT DOES APPEAR WHEN I DID A TEST FIT WITH THE STOCK AIR BOX IT FIT SO ANYONE WANTING TO UPGRADE THE REAR SHOCK WITH OUT GETTING RID OF THE STOCK AIR BOX HERE YOU GO.
YSS PRO-X SHOCK
$ 79.00
MODEL / PART # OD220-280P-01
https://scooterswapshop.com/collections ... ro-x-shock
http://www.yssshocks.co.uk/products.html
Tue Jul 17, 2018 4:10 am
Post SEAT#2
THIS IS THE 2ND ROUND FOR A SEAT FOR ME, I DID CHOP A SEAT THAT WAS A DOUBLE INTO A SINGLE BUT THIS ONE IS FROM A 1989 YAMAHA ZUMA SINGLE SEAT AND SINGLE SEAT GAS TANK I DID. I DID MEDIA BLAST THEN POWDER COAT THE GAS TANK AS WELL. ON THIS I HAD A SHOP REWRAP THE SEAT.
Tue Jul 17, 2018 4:19 am
Post CARB
THIS IS THE POLINI CP 24MM EVOLUTION CARB
FILTER SIDE IS 60MM AND INTAKE SIDE IS 30MM
IF YOU HAVE THE STAGE 6 DOUBLE REED INTAKE YOU WILL NEED
- ADAPTER 30MM FOR STAGE6 INTAKE ( TM24 ) MODEL: S6-32ET030 $15.19
- AIRFILER POLINI EVOLUTION ( 60MM ) MODEL: 203.0164 $39.99
- POLINI CP 24MM EVOLUTION CARB MODEL: 201.2400 $123.76
https://scooterswapshop.com/collections ... m-evo-carb
https://www.scootertuning.ca/en/air-fil ... &results=1
https://www.scootertuning.ca/en/intakes ... &results=1
Tue Jul 17, 2018 4:24 am
