View unanswered posts | View active topics It is currently Mon Sep 23, 2019 4:42 am
 Zuma won't start
Post Zuma won't start
Hi,
I just bought a used 2009 Zuma 125. It was working fine until it stalled while on a ride. It now only starts when giving it gas, and dies when you let off. I've checked the following: Spark plug, cap, cable, coil are all okay. Fuel Injector sprays mist. Fuel Pump primes. I will check fuel pump with starter fluid next, and check compression.
What is the issue? Bad fuel pump? Any help would be appreciated!
Here is the video of what it sounds like:
Mon Mar 11, 2019 1:50 pm
Post Re: Zuma won't start
Have you taken your VIN # to your yamaha dealership to make sure the recall was ever done on the fuel pump? That's one of the 1st things i did when i got my 2009.
2009 Zuma 125
RC Scooters 155R BBK
Mojo Customs stretch kit
Yoshimura TRC Race Exhaust System
TST variator
KOSO afterburner tail lights
LED headlight and front blinkers
Highway bars
Simota air filter
Tue Mar 12, 2019 11:48 pm
Thanks for the tip. No I have not taken it to a dealership yet. I tried cleaning out the fuel injector a couple days ago. It still has a hard time starting, but if I just give a little throttle for 20 seconds, it doesn't stall. Still not sure what the problem is though!
Wed Mar 20, 2019 1:17 pm
Anything that starts with gas and dies when you let of the gas start looking for a vacuum leak in the intake area
Thu Mar 21, 2019 12:48 pm
