View unanswered posts | View active topics It is currently Tue Jul 17, 2018 2:12 pm
Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
 Riding in shorts? Problem!
scooters and mods: Soon to be 09' Zuma 125
Post Riding in shorts? Problem!
Alright I know riding in shorts isn't the safest thing to do, but I do it anyways (in the summer time it's way to effing cold right now).
Anyways I HATE when my shorts catch the wind and raise / ride way up on my leg. I wear below knee length shorts.. What do you guys do about this? Kinda random but I got some pretty white legs, I really don't care much, but if it can be avoided...
Fri Jan 28, 2011 9:17 am
Post Re: Riding in shorts? Problem!
doesn't matter what the summer temps are. i always have jeans and boots when i ride. road rash sucks. leave the shorts at home when riding.
if they are below your knee, are they really shorts?
Fri Jan 28, 2011 11:56 am
at a certain point i believe they classify as "capris" lol
Member 2671
Darkness
2002 Bugeye
70cc Top Trophy Kit
Dellorto 21mm PHBG Carb
Doppler Air Box
YMW V8 Exhaust (high temp paint added)
Stage 6 16x13 sport pro variator
Stage 6 sport pro 107mm clutch
Stage 6 Wing cooler clutch bell
Yellow Malossi Contra
Stebel Magnum Horn
Fri Jan 28, 2011 1:08 pm
Have you considered pink tights?
Fri Jan 28, 2011 1:25 pm
Road rash does suck and i've had it before. I know the consequences I take when I wear shorts when I ride.
I hate pants for the most part, but I do think some jeans are pretty cool and stylish. When I said I wear my shorts below the knee I didn't mean that I'm some gangster thug who has my shorts down to my ankles.
For example, I'll wear shorts to the gym which is only like 8 miles away from my house. Like I said, I hate when they ride up mid thigh when they catch wind. It's a little embarrassing cause I got some pretty white legs haha. I don't care that much cause I still rock shorts, I was just wondering if anyone has maybe had the same problem and found some kind of clever solution.
Fri Jan 28, 2011 1:29 pm
My GF got mad at me for stealing hers. She took them back :[
armoured riding pants
where them while you are scooting take them off when you get where your going
Fri Jan 28, 2011 3:46 pm
I wear cargo shorts. The extra pockets make them a little stiffer and no problem.
It is better to travel well than to arrive.
The Buddha
Fri Jan 28, 2011 4:40 pm
scooters and mods: 2008 50 cc Zuma stock
I was going to suggest pink panty hose worn outside the shorts, but I guess that is too similar to Nick's suggestion of pink tights.
Fri Jan 28, 2011 5:50 pm
scooters and mods: 2003 Yamaha Zuma Dual Headlight Mod
You could always use some velcro straps, and wrap them around the bottom of the shorts. I've done this when I ride a bicycle in jeans, that way the bottoms wouldn't get wrapped up in the chain, but I think it could be used to keep your shorts from riding up.
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
Stage6 WingCooler bell
Malossi white contra
C3 Mirrors
Stage6 CNC brake levers
JDM Fender With Clear Lenses
MORE COMING SOON!!
My Zuma
ChuckD420's 2003 Zuma
Fri Jan 28, 2011 5:53 pm
scooters and mods: Zuma 125
How about pants with zip-off legs?
Fri Jan 28, 2011 6:22 pm
You know I had this problem with my v strom, but both my zumas my shorts stay put.
Maybe because my legs are super muscular, who knows.
Im 6"1' if that matters
Fri Jan 28, 2011 7:24 pm
99% of the time I fight the urge to wear shorts.
I just think that I'm safer that way ...
We used to have some ALL THE EQUIPMENT...ALL THE TIME guys.
I'm not that bad but, I've torn up the skin on my knees and elbows before. Hurts some.
Sat Jan 29, 2011 6:51 am
scooters and mods: 2008 Zuma: LV ZX pipe, CF reeds, 1/2 stock 1/2 LV rollers, clutch springs, 86 main jet, Top Trophy 70cc kit
If i'm wearing some baggy shorts, I have the same problem, I've tried to just kinda tuck them under my knee's a little bit to try to get them to not catch the air. other than that, just be proud of your extreme white guy tan and be happy that it is warm enough to wear shorts!
Sat Jan 29, 2011 9:27 am
haha showers are the worst w/ Road Rash
Sat Jan 29, 2011 10:55 am
