View unanswered posts | View active topics It is currently Sat Aug 24, 2019 5:58 pm
Reply to topic  [ 11 posts ]
 RIDES - Riding Yamaha zuma across America.
scooters and mods: 2009 Zuma 125, Two Brothers Exhaust, NCY Handlebars, KOSO Afterburner LED taillights
Post RIDES - Riding Yamaha zuma across America.
Hello ZF!
Cheers.
Thu May 12, 2016 6:30 pm
Thu May 12, 2016 11:34 pm
Fri May 13, 2016 3:09 pm
Fri May 20, 2016 9:57 am
Sun May 22, 2016 10:32 pm
Thu Jun 09, 2016 10:47 pm
Sun Jul 10, 2016 6:15 pm
Sun Jul 10, 2016 6:56 pm
Mon Jul 11, 2016 9:51 am
Wed Sep 27, 2017 2:19 pm
Post Re: RIDES - Riding Yamaha zuma across America.
japanese parliament condemns Donald Trump
All public petitions that receive more than 100,000 signatures are thought to be for debate by the House of Commons. There probably will not a vote, even so, On the Trump request.
"Exclusion powers are prolonged and are not used lightly, The Home Office said in an official a reaction to the petition. "The Home Secretary will utilizing powers when justified and based on all available evidence,
jack Dromey, A manual work MP, Said Monday that he supports the ban because Trump's comments only feed into propaganda from the Islamic State in Iraq and Syria (ISIS) And undermine the safety of British citizens.
"ISIS needs jesse Trump and mark Trump needs ISIS, Dromey defined. "ISIS needs so you can say, 'Muslims you are under attack.' Donald Trump needs to say on one hand, 'You are under attack by Muslims.or,--"
"I do not think Donald Trump should be allowed within 1,000 miles of our shores, He installed.
"If we were to go at a later date of banning Mr. Trump, Where would we draw the fishing line, an additional MP said. "The way we deal with bigotry and hatred is by struggling with it head on,
Naz Shah, A manual work MP, Said she does not support an overall ban. on the other hand, She said she'd welcome him and challenge him on his views by showing him the ukraine chat British Muslim community.
don't mind the occasional division over the ban, MPs were u. s,usa in condemning Trump. They telephoned him, At all types of times, a fantastic "simpleton, one particular "Buffoon, virtually any "idiot, having a "Demagogue,
"His test is not comical, His test is not funny, His words are poisonous, Tulip Siddiq, A labor MP, acknowledged.
Sun Aug 11, 2019 1:31 pm
