View unanswered posts | View active topics It is currently Sun May 26, 2019 8:54 am
 Zuma won't start
Post Zuma won't start
So I was riding WOT into the wind and cruising at about 55. I have the 155 BBK and it does pretty good into the wind, but it was full throttle for probably 20 minutes. Power suddenly cut out, but I didn't hear any particular noises when that happened, of course it windy so maybe I didn't hear it. Any thoughts on where to start trouble shooting? Here is a video on youtube of it cranking but not starting. I thought I would take off the valve covers and peek in there. Oil and gas level good. https://www.youtube.com/watch?v=Aa3IKaoOPd8
Mon May 07, 2018 4:01 pm
Post Re: Zuma won't start
Spark fuel air and compression
Depdning upon the year there have been lots of fuel pump issues
Mon May 07, 2018 5:01 pm
scooters and mods: 2009 125
Spray some starter fluid into the intake with the fir filter removed. It should sputter if you have a fuel issue.
I'd start with a compression test since this isn't a stock motor.
2009 Zuma 125 Blue & Black - Second Engine
2009 Zuma 125 Black & Yellow (RIP)
Tue May 08, 2018 4:00 pm
Thanks for the tips. I ordered a new fuel pump. I'll start there and proceed as needed.
Tue May 08, 2018 7:32 pm
Chuddybangbang, did you ever figure out what was the issue? I'm having a very similar issue where my bike cut out too. I was able to start it right back up twice, on the third start, it made the same noise yours was making, and would only start when I pinned the throttle a bit.
Mon Mar 11, 2019 1:21 pm
