View unanswered posts | View active topics It is currently Wed May 22, 2019 2:24 am
Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 2004 Zuma 50 mph Daily Driver
Post Re: 2004 Zuma 50 mph Daily Driver Stock with Stealthy Upgrad
I recently put boppers on my bike. Very happy with them. Have definitely been able to feel the improved grip on the road, and I whole heartedly recommend them. If I recall correctly, the Reggaes are basically the stock tires. Adequate, but that's it.
05 Zuma
Stock. Blank canvas. =D
Wed May 01, 2019 8:40 pm
Thanks just ordered Boppers .
I don't go off road often enough I run alot of County Highways .
43 mph still breakin in
2004 Zuma Malossi sport 70 cc breaking in with stock pipe then Technigas next r polini 107 mm clutch polini green springs polini high speed variator 5.7 grams 82 main jet 46 pilot jet needle 1 clip rich stock 14.4 gears 46mph
Thu May 02, 2019 6:03 am
Just went over 300 miles on kit it is pushing 46-47 mph at 9200-9300 rpms so it has loosened up.
I am up about 2 mph since initial install.
9200 rpm is 46 mph
8800 rpm is 42 mph
7800 rpm is 37 mph
Next step are swapping exhaust to the next r to bring the rpms up.
and the new michelin boppers to replace stockers.
Then the next stage will be
The 2008 rear end just got here from boats .
So i will exchange that when i put on the athena gears 42/14 gears which will put me at 11 to 1 ratio .
Thu May 09, 2019 6:11 am
Have to order extra parts .
When ordering the 2008 rear end .
You need to order the fixed sheeve ,the sliding sheeve. About 50 bucks
And one more part secondary spring seat It is a $6 part .
I had the clutch off and greased the new sheeves and the 2005 does not fit .
So i ordered the right part and will replace this week .
I regreased and replaced the old torque driver for now .
Sun May 12, 2019 4:40 pm
Upgrading gears and rear sheeve tomorrow since all the parts are here and my buddy is going to let me use his press at the shop.
Looking or better shifting from the new torque driver 2008 style and higher top speed from the gears .
Savings tires and pipe till later next week.
Tue May 21, 2019 7:57 pm
