View unanswered posts | View active topics It is currently Sat Jan 19, 2019 4:07 pm
 Mouse chewed wires, no headlights
Post Mouse chewed wires, no headlights
2012 Zuma 125 starts and runs fine, but no headlights, low or high beam. Checked fuse, good. Good fresh battery. Pulled front cowl and found mouse nest and a few gnawed wires. One wire goes to headlight hi/low beam. Tail lights, brake lights, turn signals all work. Any ideas?
Sun Nov 25, 2018 6:54 pm
Post Re: Mouse chewed wires, no headlights
Take a look at this it might help sort out the wiring
this is the link to the zuma50 dual headlight
Post YAMAHA ZUMA BUGEYE DUAL HEADLAMPS HOW TO: FREE MOD BY Jdubbs
just some wire and clips to fix it.
Forum members have also used this on the 125's
Sun Nov 25, 2018 9:23 pm
Found wire that's damaged. Will have to remove ignition switch to get at it. How do I remove the switch?
Mon Nov 26, 2018 2:34 pm
Havent tackled that project
Jdubbya has the repair manuals on here .
just search repair manuals
These scooters are not that complex after you get the fairings off.
Just take your time lots of pictures and draw some diagrams on cardboard and place the screws in the right order so you can get it back together the first time .
Mon Nov 26, 2018 7:15 pm
Finally found the wire that had been destroyed. Pulled ignition and back part of fairing loose and managed to fish harness out enough to do a quick connect and splice a new wire section. Lights now work.
Mon Nov 26, 2018 8:11 pm
