View unanswered posts | View active topics It is currently Mon Jun 24, 2019 11:17 pm
 Zuma 50F stalling at lights
Post Zuma 50F stalling at lights
Heya, I have a 2012 Yamaha Zuma 50f and while waiting at traffic lights it will die when I give it gas if I am idling for 1 minute or more and the only way to start it again is to turn the ignition on and off, can anyone help me diagnose this asap please.
Thanks!!
Mon Dec 03, 2018 1:00 am
Post Re: Zuma 50F stalling at lights
A friend of mines 125 s had a fuel pump issue that he had a similar issue with .
Your bike is fuel injected like his .
He went through checking all the throttle positions sensors pulled the cylinder head and finally got to the fuel pump.
But i would start with something easier .
Do you have a copy of the service manual it is available on the forum .
Has this just started happening or is this bike new to you .
It maybe something as easy as a cracked breather hose .
Tue Dec 04, 2018 9:22 pm
