View unanswered posts | View active topics It is currently Mon Jun 24, 2019 11:11 pm
Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Newbie Just bought 1st Zuma and have question
Post Newbie Just bought 1st Zuma and have question
Hi folks! Just bought an 04 Zuma 50 that had been flooded. Im going to try and get her running again and I have been able to save quite a bit of her. How ever the carb and both clutches are too corroded to make work again.
Ebay has Chinese carbs for as low as $20. Anyone have luck with these? Are they tune able?
As far as the clutches, should I look for a good used one? Im not trying to soup her up or anything so I dont need any expensive performance parts.
Thanks for the help!
Cody
Mon Apr 15, 2019 11:25 pm
Post Re: Newbie Just bought 1st Zuma and have question
Buy a good carb otherwise you might have to pay twice.
Original carb or Dellorto is what most use on here .
if you are going to mod it get the dellorto either 17.5 mm or 19 mm
Where are you located there may be members here that would sell you there old oem carb.
Tue Apr 16, 2019 4:21 pm
Thanks Zino. I am in the Houston area. I am interested in a oem carb and clutch/variator if anyone has them.
Cody
Wed Apr 17, 2019 1:17 am
Here is a new forum member that is upgrading his carb right now
Make him a offer
member sixdown
And another recent quote within the last week of another member
boxybrown
[quote"boxybrown"]I have a lot of extra parts, I’ll send you a message.[/quote]
Search them out and PM them
AS far as clutch the 2002 -2005 whole rear assembly is 105 mm 2 shoe clutch with a poor designed torque driver.
https://www.scootertuning.ca/en/variato ... 107mm.html
this is a upgrade and the price is better than oem and will hold upto further mods
They also have variators any sport variator is a good upgrade .
Wed Apr 17, 2019 6:19 am
Wow Zino, thanks for that info. That secondary clutch looks to be just what I need. If I go with that do I need to get a new matching VARIATOR also or could I use a oem one? They seem to be out of stock on the standard ones.
Thanks again!
Cody
Thu Apr 18, 2019 2:23 am
No you can keep a stock variator or aftermarket you can mix and match brands .
For example I have polini ,athena ,malossi parts mixed with oem.
The sport variators are a simple swap with no case modding for oem .
Just dont expect big speed or acceleration with the variator swaps they might add a mile or 2 or nothing at all they really just smooth out shifting and acceleration.
That vendor is very good and dont despair they constantly replace stock The weather is causing a run on there stock.
Thu Apr 18, 2019 5:50 am
Good resource about clutch, thanks!
Mon Apr 29, 2019 6:48 am
I just sent you a pm i have some extra parts in good condition full variator and clutch and torque drivers .
Mon Apr 29, 2019 6:20 pm
Thanks Zino! I had already ordered this clutch https://www.azscooterparts.com/minarell ... lutch-bell and a variator from them. I just received the rest of my parts today and will begin the rebuild this weekend. (New crank, piston, rings, cylinder, seals and bearings etc.) Will keep posted upon progress.
Cody
Wed May 08, 2019 1:43 am
awesome stuff
try to not change too many things at once so you can enjoy the up grade and if something seems to degrade performance you can rule it out because you only changed one thing at a time.
list the parts you bought and keep us updated with mods and results so you can help others
also
post a signature so others can help and see what year and what mods you are running.
for example
80 main stock carb 6.5 gram rollers stock variator stock exhaust 37 mph
Here is how to post your signature
At the very top of this screen it says "user control Panel"
Log in there
On the left hand side of the user control screen under options
Log into profile
2nd one down is your signature
Just update and keep going you also could set up a build thread .
Wed May 08, 2019 5:11 am
The 04 flooded Zuma revival progress. Some tear down pics.
Cody
Wed May 15, 2019 10:29 am
Received most of the new parts and started the rebuild. New crank and bearings, piston, cylinder, clutches. All oem except clutch and variator.
Cody
Wed May 15, 2019 10:47 am
I had a problem when installing the variator and starting gears. When torqueing the nut the crank would bind and lock up. After pulling it apart and studying it I found that the variator would bind on the starter clutch. Turns out I hadn't installed a collar between the starter clutch and variator. Nowhere in the shop manual did I find where it says to install this. I found the problem by studying a parts diagram. Its #11 in the pic. Did Yamaha forget to add this in the manual. I later found a you tube vid where a guy had same issue. https://www.youtube.com/watch?v=cONBx0oibd0 Hope this helps others.
Cody
Wed May 15, 2019 11:15 am
Cody
Nice work .
Awesome Pics
Since you are doing a full tear down and Build up .
How extreme are you going on bringing her back?
Stock ,Sport, Mid Race
Post up your sig with your mods over stock.
With your pics you are bringing alot of help to others
Wed May 15, 2019 2:06 pm
Cody
You should start a build thread so others can follow your progress and results .
And after looking at your shop I need to clean mine way up before I take pictures .
Log in there
Log into profile
2nd one down i your signature
Just update as you go
Wed May 15, 2019 2:10 pm
