View unanswered posts | View active topics It is currently Thu Sep 19, 2019 6:51 pm
Reply to topic  [ 12 posts ]
 The 2004 Zuma Journey
scooters and mods: 2004 Yamaha Zuma
Post The 2004 Zuma Journey
Howdy Zuma Community-
I recently purchased a 2004 Yamaha Zuma with 6k miles, and it's been so much fun! This little guy starts up quick with the slightest touch and can really get going- I reach 40mph with no issues and keep up with traffic to my surprise (haven't tried higher speeds ¯\_(ツ)_/¯). I bought the scooter from it's original owner, who I can spent time working on the bike over the years. After I let him know I didn't know ANYTHING about scooters but hyped to learn and work on it, he gave me a box of brand new Zuma parts.
I don’t even know where to start??
Here's a majority of the parts I have:
    Airsal cylinder
    Second unknown cylinder
    Polini clutch torque springs
    Assortment of ring gaskets (different colors if it matters)
    NCY racing clutch
    Athena weights
    Piston kit
    Loads of extra small unopened screws, rings, and pieces I can't describe
I have no clue whats installed currently- expect its fast... and the scooter wants to go FAST. What’s some basic things to keep in mind to maintain an older bike and keep this spunk and power in my new friend?
(forgive my lack of knowledge)
Thu Jun 06, 2019 9:32 pm
Post Re: The 2004 Zuma Journey
Welcome to the forums .
Enjoy your zuma .
The stock 2004 just touch 40 mph so if you are puling wheelies or burying the needle past 40 you already have some upgrades.
If you want to take pictures of what your pipe carb and cylinder look like we could tell you more .
They are very fun to build up .
These are easy to maintain being a 2 stroke You have less moving parts in the engine.
The number 1 thing you need to keep track of is what your spark plug looks like It will tell you if your engine is healthy.
With the proper jetting .
Here is the service manual
http://www.zumaforums.net/servicemanual ... Manual.pdf
Checking belts ,changing oil ,brakes ,tires ,roller weights ,cleaning and oiling the air filter all easy stuff.
Fri Jun 07, 2019 5:18 am
Are those cylinder kits or just the cylinder .
They need to me matched up with a piston that fits the kits so that the ports on the pistons match up to the ports on the cylinder.
The ncy clutch, polini springs and athena weights are plug and play and can be added with other parts .
The springs and weights are for adjustment .
Enjoy what you have so you get used to how it accelerates handles and top speed.
Then look at upgrading one area at a time so you can feel the change and if you dont like it you can change back.
Rookie mistake is change too many things at once and then it runs poorly and you cant figure out what parts are installed wrong.
You have some good stuff there.
Fri Jun 07, 2019 5:28 am
Thanks zino-
I’ve been going through the service manual and it’s really helpful.
I’ll be back here to get help with the performance build up of my scooter- still trying to even get a picture of the inside because the last few days I’ve been buying different tools to discover I need another tool to get anything fully off....
I met the owner of a local scooter shop, I stop in every few days, he’s been chill about helping me understand spark plugs, 2-stroke oils, and basic maintenance. Overall the scooter community is rad.
Thu Jun 13, 2019 10:04 pm
The two cylinders are kits; complete with their own pistons, pins, and all that jazz.
While the second cylinder I didn’t know is actually an Athena.
The separate/spare piston kit is just Yamaha.
And “different” colored gaskets I wasn’t sure about are actually just copper. derp
I found some aftermarket turn signals in my box I thinking of starting there perhaps.
Thu Jun 13, 2019 10:32 pm
The athena kit comes with a ton of gaskets and is a great cylinder up grade is it noticeably larger than the stock yamaha ones .
Take alook at your current set up and see if where your exhaust hooks up if it is a grey aluminum cylinder the exhaust hooks into or cast iron.
Make a run at top speed if you are hitting 45 or burying the needle you are beyond stock with a few pieces .
Sun Jun 16, 2019 3:07 pm
Looks like there is currently an Athena cylinder in there- I can't fully get everything off to see the whole thing but am I going to get better performance with this or the Airsal?
I fucked up trying to get some of the screws off and I think I ended up stripping them... had to take a break and step away... oops.
And I can't get the big bolts off of the clutch housing to get the NCY racing clutch added.
Thu Jun 27, 2019 10:15 pm
If you are talking about the nut on the clutch .
Buy a rubber strap wrench from a local auto parts store .
Have a buddy hold the clutch with the strap wrench
and then use a long handled socket to take the clutch off it is only on there with 30lbs so it is pretty easy to break loose.
as far as though screws by the cylinder a vise grip would work .
I switched alot of screws out for allen heads
Fri Jun 28, 2019 6:18 am
Any updates on your build ?
Fri Jul 19, 2019 5:37 pm
Haha... Let’s just say, I have accumulated a wide range of tools.
I’ve been sweating, crying, screaming in this summer heat. Im not going to give up man.
I’ve tried everything to get this clutch bolt off... everything but a damn drill/electric driver.
Otherwise, I’ve only made changes to the body. Buying new fenders, foot board, random tubes and plastic parts here and there. Nothing performance. :(
Mon Aug 05, 2019 11:50 pm
I need to get that fucking screw off.
Now I’m working on getting a high powered impact driver and bust that dookie off. Though those don’t seem to come cheap.
Tue Aug 06, 2019 12:01 am
harbor freight has a impact that will work I believe it was 50 bucks .
Tue Aug 06, 2019 5:35 pm
Users browsing this forum: VincentWen and 0 guests
