View unanswered posts | View active topics It is currently Thu Sep 19, 2019 6:56 pm
 2014 Zuma 50 Electrical Battery Drain
Post 2014 Zuma 50 Electrical Battery Drain
Hi All,
I have a 2014 Zuma 50 scooter that was attempted to be stolen, they clipped the wires by the key harness and attempted to hot wire it with no luck, stashed it in the bushes and the cops found it and called me. Now I have a battery drain. Any ideas what it could be?
Thu Jun 13, 2019 5:51 am
Post Re: 2014 Zuma 50 Electrical Battery Drain
Do you have a multimeter or can you get a hold of one to track down the short .
Start with what the ignition wires they messed with then check the easiest parts head lights break lights turn signals .
You have a big job ahead .
Thu Jun 13, 2019 8:15 am
Users browsing this forum: VincentWen and 2 guests
